ᐅ Help! Is this really the current state of technology?
Created on: 10 Jul 2016 23:30
Gerrit
Hello everyone, the tiling work in our new build has been completed. We are far from satisfied with the results. The tiler says everything is within tolerance, but we find that hard to believe. That’s why we wanted to get some independent opinions. What do you think? Were the work carried out according to recognized standards and technical rules or relevant DIN regulations?
We would appreciate any helpful responses.
Best regards, Gerrit
Close-up of a door frame on the floor covering with sealant and dust
Close-up of a white window frame with damaged wall edges
Kitchen area with dark granite countertop and dark tiles
Close-up of a white door frame next to tiles inside the building
Close-up of a small gap in a stainless steel surface, indicating construction defects.
White door frame with gray baseboard on dark floor indoors
White kitchen fronts with door panel, window frame and dark floor.
Gerrit
11 Jul 2016 20:29
We would also prefer if the tile had been laid all the way up to the riser. We have never seen this type of execution before. Is there no recognized standard practice for this?
Sebastian79
11 Jul 2016 20:54
No, something like that must be mentioned in advance.
Legurit
11 Jul 2016 21:15
I don’t find it that problematic – at least you can clearly see where the staircase begins.
Payday
13 Jul 2016 15:25
Regarding the staircase, there isn’t much that can be done now. The height of the last granite piece is fixed anyway; it was probably not cut on site. Since a whole tile was used after that, it can’t simply be replaced either. The entire hallway would need to be redone, which no one will accept.
It’s a different matter with the missing miter joint on a 90° corner. That is really unacceptable and can be relatively easily replaced. Otherwise, there are a few things that don’t look great but are still within acceptable tolerances. The tiles also have some manufacturing tolerances.
PS: If someone claims that anything goes according to the DIN standards, ask to see the actual DIN document. NO ONE actually has the real DIN, and they will then make corrections ^^ they are all bluffing, I don’t know anyone who really owns the DIN.
Sebastian79
13 Jul 2016 16:20
So my tile layers had the DIN standards on hand – the screed installer as well. Or what did you mean by that?
Mycraft13 Jul 2016 19:17
Excerpts are freely available, and the complete DIN standards can be purchased, but you don’t have to follow them if you don’t want to... the same applies to the miter joint... if it wasn’t agreed upon beforehand, then it is not required, and you can choose whether to do it or not...
