ᐅ Help! Is this really the current state of technology?
Created on: 10 Jul 2016 23:30
Gerrit
Hello everyone, the tiling work in our new build has been completed. We are far from satisfied with the results. The tiler says everything is within tolerance, but we find that hard to believe. That’s why we wanted to get some independent opinions. What do you think? Were the work carried out according to recognized standards and technical rules or relevant DIN regulations?
We would appreciate any helpful responses.
Best regards, Gerrit
Close-up of a door frame on the floor covering with sealant and dust
Close-up of a white window frame with damaged wall edges
Kitchen area with dark granite countertop and dark tiles
Close-up of a white door frame next to tiles inside the building
Close-up of a small gap in a stainless steel surface, indicating construction defects.
White door frame with gray baseboard on dark floor indoors
White kitchen fronts with door panel, window frame and dark floor.
11 Jul 2016 13:47
Sebastian79 schrieb:
I wouldn’t recommend using gypsum in wet areas; instead, you should have the tiler come back to redo the grout or tell him which grout material was used.
You’re right! I assumed these were not wet areas—using gypsum on a windowsill or some corner near a door is not an issue. After all, there are also gypsum-plastered walls in bathrooms 😉
From the pictures, I see a window corner.
Sebastian79
11 Jul 2016 13:49
No, but the photo with the hole showed a floor tile. Otherwise, I wouldn’t consider that problematic either—though the grout color would need to match. For example, none of the grout in our house has a gypsum-like color.
Neige11 Jul 2016 16:16
Koempy schrieb:
How did you imagine the top stair step?
For me, having the riser below the floor tile would have looked better.
Steffen80
11 Jul 2016 16:44
Oh dear... if someone expects me to do something like that, it would be suffocating 😉 That definitely wouldn’t meet my standards, especially not in a newly built home!!!
Sebastian79
11 Jul 2016 16:46
What is the difference between new construction and existing buildings?
Steffen80
11 Jul 2016 16:55
Exactly! There really isn’t any! In both cases, it looks like it was done by an amateur!
