Henny071015 Sep 2017 10:53Hello forum members,
I would like to hear your opinions and recommendations on how to keep my garage frost-free.
I am from Lower Saxony.
The garage is about 30 sqm (320 sq ft) in size.
The walls are 17.5 cm (7 inches) sand-lime brick with exterior facing bricks.
The roof is a standard flat roof without insulation.
Using a gas heater or wood heating is not an option because, in case the garage is ever used for gatherings, I would prefer to heat safely with electricity.
I am considering mounting either a fan heater or a convector heater on the wall. Is 2 kW sufficient?
Or do you have other suggestions?
Bau-Schmidt15 Sep 2017 12:50I would just say expensive fun, and 2 kW is not enough.
Knallkörper15 Sep 2017 22:26It looks like only a wood stove will be sufficient. An electric heater with 2 kW is not enough, and 3 kW is also insufficient. I know this "unfortunately" from experience during construction; our garage is similar, but our walls have an insulation layer behind the brick cladding. Using a gas heater introduces too much moisture into the room.
