ᐅ Garden Water Meter Permanent Installation
Created on: 5 Apr 2020 08:09
tim2111
tim2111
5 Apr 2020 08:09
I need your expert advice.
I wanted to install an outdoor water meter for the garden and assumed—since I’ve had one before—that it would be fairly simple to use a screw-on meter at the external tap. However, after checking with the local utility company here, they do not allow such meters, even with a seal. The meter must instead be permanently integrated into the household plumbing system.
So far, so good.
What practical options are there if the indoor piping doesn’t accommodate this? The outdoor tap is located on the ground floor and there’s no separate supply line in the basement where a meter could be installed; otherwise, all other water consumption on the ground floor would also be included. The outdoor tap itself is a frost-proof valve from Kemper—could a meter perhaps be integrated there somehow?
Thanks in advance for your help!
Mycraft5 Apr 2020 09:14
Yes, this is generally how it is done here:
tim2111
5 Apr 2020 09:28
Exactly, that's how I know it as well. However, the utility company’s statement is very clear: they no longer allow this, not even if sealed by yourself. The meter must be an integral part of the house installation :-(
rick20185 Apr 2020 09:37
It varies from municipality to municipality.
Try calling again. Sometimes it depends on the staff member...
and ask them to send you the regulation where it is described.
With low consumption, the costs for an additional meter (calibration; fees, regular replacement, etc.) are usually not worthwhile.
HilfeHilfe
5 Apr 2020 10:37
We have a Gardena meter installed... Besides, what do you want to achieve with the meter? Just statistics? Then install one like that. No one has ever been in our garden.
Mycraft5 Apr 2020 11:53
Avoid estimated costs. This varies depending on the municipality. In our case, wastewater is not charged on garden water use, which saves a considerable amount.
