ᐅ Garden Water Meter Permanent Installation
Created on: 5 Apr 2020 08:09
tim2111
I need your expert advice.
I wanted to install an outdoor water meter for the garden and assumed—since I’ve had one before—that it would be fairly simple to use a screw-on meter at the external tap. However, after checking with the local utility company here, they do not allow such meters, even with a seal. The meter must instead be permanently integrated into the household plumbing system.
So far, so good.
What practical options are there if the indoor piping doesn’t accommodate this? The outdoor tap is located on the ground floor and there’s no separate supply line in the basement where a meter could be installed; otherwise, all other water consumption on the ground floor would also be included. The outdoor tap itself is a frost-proof valve from Kemper—could a meter perhaps be integrated there somehow?
Thanks in advance for your help!
Mycraft5 Apr 2020 14:26
No, that is absolutely common.
Even in a new build, I don’t see any problem with installing a new tapping point.
guckuck2
5 Apr 2020 14:26
What does unreasonable mean? You just pay wastewater fees on your garden water, like your neighbors do.
Flocko1
5 Apr 2020 14:29
Collect rainwater to save on wastewater charges
hampshire
5 Apr 2020 14:48
tim2111 schrieb:
Isn’t it unreasonable for the municipality to demand something like that?
It may be incomprehensible, uneconomical, or simply exaggerated. Anyone who sees this as “unreasonable” probably has had a very sheltered life. Calculate the ROI for yourself and then decide—it’s not difficult. It’s not something to get upset about.
Snowy36
5 Apr 2020 17:45
Can someone please explain to me in more detail why you would want to have this?
You would only need it, if I understood correctly, when watering the garden using the household water supply line so that you don’t have to pay sewage charges on the water used, right?
If I water using rainwater tanks, I can skip this, can’t I?
rick20185 Apr 2020 17:55
@Snowy36 Exactly. Or if you regularly refill the cistern with fresh water.
