ᐅ Looking for a concrete slab contractor in the Stuttgart area.
Created on: 3 Mar 2021 22:37
BenBaut
Hi everyone,
Which ground slab contractors from the Stuttgart area would you recommend?
BenBaut
BenBaut
BenBaut schrieb:
Where is the problem then?If everything is done correctly, there is none. But consider the following common mistakes: errors in site staking that result in the foundation slab being incorrectly positioned; mistakes in measuring the excavation or in interpreting the levels before and after placing insulation, leading to the slab being at the wrong elevation; working from outdated plans despite changes in the meantime, such as a shift in the wall location between the utility room and pantry, causing downpipes to end up on the wrong side of the partition wall, and so on. If you, as the person responsible for organizing the foundation slab work, effectively subcontract the product from the previous supplier, you no longer stand clearly on the client side towards the house supplier, but find yourself in a sandwich position. You’ll be really anxious until the grounding conductor inspection report is safely stored ;-)As a house supplier, I also wouldn’t want to occasionally replace my reliably performing foundation slab installer with someone preferred by the builder just because of a price difference.
Conclusion: if you like the thrill and you are the one responsible for the removal of the slab, then procure this part separately – but if your house supplier is the one pushing for this removal, then send them packing.
