ᐅ Floor Plan – Home Construction 2015 – Your Opinions Are Greatly Appreciated
Created on: 5 Feb 2015 22:51
project2015
Following a suggestion, I created a new thread to discuss the floor plan (thanks Yvonne).
Attached are two versions based on our requirements (a family of four, hopefully a third child in the future) regarding the living concept and the plot situation (new development area, 685m² (7368 sq ft), not on the edge but centrally located). The site plan already shows an older version (now discarded).
I’m interested in your opinions, as I’m quite uncertain about the design of the rooms on the upper floor. The basement is also not fully planned yet, so I would appreciate any help.
Lageplan eines Baugrundstücks mit rot markiertem Haus auf Parzelle
Dachgeschoss-Grundriss mit Eltern- und Kinderzimmern, Bad und Treppe
Grundriss eines Hauses mit Küche, Ess- und Wohnbereich sowie Garage
Grundriss Kellergeschoss mit Hobbyraum, Bad und Gästezimmer
Schnitt durch mehrstöckiges Haus mit Rohbau, Stockwerken und Dachkonstruktion
2D Grundriss des Dachgeschosses mit Eltern- und Kinderschlafzimmern, Flur und Bad
Grundriss eines Einfamilienhauses mit offener Küche, Essbereich, Wohnzimmer und Garage.
2D-Grundriss eines Hauses mit Hobbyraum, Gästebereich und Bad
Architekten-Schnitt durch ein Wohnhaus mit Dach, Grundrisslinien und Maßangaben
Legurit
6 Feb 2015 11:46
Not necessarily, but it does depend somewhat on the dimensions of the building plot. Alternatively, you could move the house slightly toward the southwest and place the garage perpendicular to the house – however, that would sacrifice some garden space.
project2015
6 Feb 2015 12:10
The building envelope is shown in the drawing above. I believe it is 18m (59 feet) from the street.
With the 40° rotation you mentioned, the living room would face more towards the south, but my main entrance would then shift towards the north, correct?
This means the entrance would no longer be "central" to the street but rather more to the side, where the driveway is currently located...
Legurit
6 Feb 2015 13:32
Yes, exactly.
project2015
6 Feb 2015 14:03
Thank you, I will bring that up.
If I could just come up with an idea for the visual offset between the living and dining areas... then it’s slowly coming together 🙂
project2015
6 Feb 2015 20:37
@kbt09:
kbt09 schrieb:
I don't see additional benefits of the "bay window" in the living area with option 2, but the benefit in the hallway is noticeable.
Do you have another idea for that? With the house width, living/dining without a bay window seems too narrow and corridor-like to me..?
backbone23
7 Feb 2015 13:07
Option 1 without a recess in the children's room.
