ᐅ Insert Fireplace Unit – Which Manufacturer?
Created on: 1 Aug 2018 19:02
Grantlhaua
Grantlhaua
1 Aug 2018 19:02
We are getting a wood stove with glass panels on three sides to serve as a room divider between the living room and dining room. Unfortunately, I don’t have enough information about the individual manufacturers to properly evaluate the offers.
Which fireplace inserts do you have? Leda, Brunner, Schmid, Hark? And what experiences have you had with them?
Domski
1 Aug 2018 22:04
Is it installed inside a sauna? If not, I would reconsider the all-around glazing.
In any case, choose the model with the lowest absolute heat output.
Brunner is top-quality, premium class.
Schmid is a good mid-range option. It is mentioned here.
I cannot comment on Leda and Hark.
Grantlhaua
2 Aug 2018 00:16
Domski schrieb:
Is it located inside a sauna? If not, I would reconsider the full glass enclosure.
Do you think it heats the room that way? The affected room is almost 65m² (700 sq ft). Friends of ours have a similar stove and basically no issues with the temperature.
Domski schrieb:
Brunner is top quality, premium class.
That would be my favorite as well since it’s local and a great product. However, the price spoils it a bit. That’s why I’m asking here for alternatives.
Grantlhaua
2 Aug 2018 00:19
Domski schrieb:
Is it installed inside a sauna? If not, I would reconsider the full glass enclosure.
Do you think it heats the room that way? The affected room is just under 65m² (700 sq ft). Friends of ours have a similar stove and actually don’t have any issues with the temperature.
That would be my preferred choice as well because it’s local and a great product. However, the price spoils it a bit. That’s why I’m asking here for alternatives.
Bookstar
2 Aug 2018 20:33
The heating capacity is not the decisive factor. Much more important is whether the stove can store the heat or releases it immediately. A 10 kW (kilowatt) stove can be perfectly fine, while a 4 kW (kilowatt) stove without heat storage capability can turn your house into a sauna.
Domski
2 Aug 2018 21:28
With three sides made of glass, heating capacity would be very important to me. Nevertheless, the issue of thermal mass also plays a role.
