ᐅ Fitting a Billy Regal with Wheels – Is It Possible?
Created on: 6 Jun 2024 10:27
TIMGE
TIMGE
6 Jun 2024 10:27
I am currently considering whether it is technically and practically possible to equip a Billy shelf from IKEA with rims/wheels. Specifically, I mean replacing the standard shelf feet or base plates with car rims – basically as a decorative and possibly functional piece of furniture.
I am particularly interested in whether the rims can safely support the weight of a fully loaded shelf, if there are any special requirements or limitations regarding stackability or stability, and what preparatory work would be necessary, such as appropriate fittings or fastenings for the rims.
Does anyone have experience with such modifications? Or have you ever seen rims used as supports for furniture? I would appreciate any experiences, tips, or warnings to help me properly assess this project.
loken
6 Jun 2024 11:42
Hey TIMGE,
cool question! 😄 Using rims as shelf supports definitely catches the eye and can look really stylish if done right. From a technical perspective: rims are designed to bear a lot of weight since they’re built for cars. This means they’re strong enough to support a shelf with books or decorative items.
It’s important to secure the rims well to prevent tipping or slipping. Maybe use a floor screw through the center mount, attached directly to the shelf base. Also, depending on the height of the shelf, the rim can be a very stable support, adding a unique look and some flair.
The “look” will, of course, depend on the size and width of the rim, but it will definitely break up the typical Ikea vibe—that’s the exciting part :-)
Good luck with your project, and feel free to share how it turns out!
Lucien
6 Jun 2024 13:58
Regarding the question of whether a Billy shelf unit can be equipped with wheel rims, here is an objective assessment:
1. Load capacity: Wheel rims are designed to bear the weight of a vehicle (usually between 300 and 600 kg (660 to 1,320 lbs) per wheel). Therefore, the load capacity for a shelf level is generally not an issue.
2. Attachment: Since wheel rims usually have a central mounting hole, the connection to the shelf can be strong if suitable screws and adapters are used. Mounting on the shelf legs or directly to the cabinet body is possible but requires precisely fitting components.
3. Stability: It is important that the rim sits flat on the floor and that the shelf does not wobble. Spacers or rubber buffers may be necessary for cushioning and stabilization.
4. Safety concerns: Sharp edges on the rims should be deburred to prevent injuries.
Conclusion: Technically feasible and stable if done properly, but it requires craftsmanship and appropriate materials. There is no general restriction, but the implementation must be individually adapted.
Leote
7 Jun 2024 08:33
Lucien schrieb:
Attachment: Since rims usually have a central mounting hole, the connection to the shelf is load-bearing
Exactly. It’s best to create a sturdy screw mount at the center of the rim; this provides the strongest and most secure hold.
LOGEMIN
7 Jun 2024 14:59
I would like to add some practical tips to this topic:
1. Inspecting Rim Cleaning: Old rims may have rust or dirt – cleaning, sanding, and painting are recommended.
2. Adjusting the Height: Rims are often about 15–20 cm (6–8 inches) tall; you should plan the shelf height accordingly.
3. Fastening Elements: Using an M8 or M10 threaded bolt through the center of the rim into a sturdy wooden board beneath the shelf has proven effective.
4. Preventing Scratches: Rubber or felt pads between the rim and the floor help protect the flooring from damage.
5. Safety: Shelves should be further secured to the back wall or with brackets to reduce tipping risk and ensure stability.
Summary: A combination of thorough preparation, secure attachment, and safe anchoring ensures that your Billy shelf with rims works cleanly and safely.
