ᐅ EPS external insulation in contact with ground (adhere XPS?)
Created on: 12 Oct 2025 12:01
Thorsten84T
Thorsten8412 Oct 2025 12:01Hello,
I am currently renovating the driveway at our house and have removed all the paving stones. I noticed that the insulation (probably XPS) extends all the way to the edge of the reach. Additionally, I found a small cavity in some spots, likely only at the level of the base slab. I read that EPS should not be in direct contact with the soil because it can potentially absorb water.
My question is: Should I fill the cavity and a small section below the insulation with XPS?
A few details:
![1760262396474.png"]93099[/ATTACH]<br />
<br />
I also tried to capture an image of the cavity with a camera.<br />
<br />
[ATTACH type="full" alt="Left 2D floor plan with camera position, right wall area with plaster and insulation](/attachments/93102/)
Note:
A few details:
- The house is 20 years old and has not had any moisture problems so far.
- It is a bungalow with a wide roof overhang, so the wall rarely gets direct rain exposure.
- The cavity is more than 2cm (about 1 inch) deep in one spot, but almost nonexistent (<3mm) in others.
Note:
- In many areas, I am not sure which materials were used or exactly where the wall begins...
- The timing of my question is because I currently have access to the wall.
