Why not consider a climate split system instead? Infrared heaters convert 1 kWh of electricity into a maximum of 1 kWh of heat. With a climate split system, you can get at least 3 kWh of heat from 1 kWh of electricity (depending on the model and outdoor temperature, even more). It might even be cheaper since, depending on the size of the house, you only need one or two indoor units, whereas infrared heaters have to be installed in every room.
Elina schrieb:
Why not consider a heat pump system instead? Infrared heaters convert 1 kWh of electricity into at most 1 kWh of heat. With a heat pump system, you can get at least 3 kWh of heat from 1 kWh of electricity (depending on the model and outdoor temperature, it can be even more). It’s probably even cheaper since, depending on the size of the house, you only need one or two indoor units, whereas infrared heaters have to be installed in every room.» So the topic of a "heat pump system" is new to me. I’ll look into it!
