The house construction will start soon. Can anyone estimate how much the earthworks will cost or share their experience? How is it usually calculated?
The building site is in Bavaria, 160 sqm (1720 sq ft) plus basement, double garage (not basemented), with what appears to be normal soil at first glance.
Grantlhaua3 Apr 2019 14:25Snowy36 schrieb:
What determines whether the soil is removed or kept? I’m quite surprised that all our soil was transported away at great expense and then the area was filled with crushed concrete. Our neighbor, however, kept all the clay soil and used it as backfill?!Using crushed concrete is a safer option because it prevents settling. With soil, even if you compact it thoroughly in a house with a basement, there is always a chance it will settle over time. We also used soil as backfill but obviously had to remove a lot since there’s naturally a lot of excess with a basement. In our case, crushed concrete is placed on top of the backfill, and then paving stones or terrace flooring are installed over that.
HilfeHilfe3 Apr 2019 16:53Please share what the costs are.
Bauherrin928 Apr 2019 10:45We have received an offer of just under 13,000 euros for
- Excavation of the foundation pit and backfilling
- Removal of the excavated material
- Connection to the existing manhole
- Stormwater pipes including excavation work
- Utility lines including excavation work
Bauherrin92 schrieb:
We received a quote, just under 13,000 eurosA basement (excavation)?
With materials, for example, for the crane setup area, the surface for the foundation slab?
