ᐅ Double or single drywall installation
Created on: 21 Mar 2016 22:18
Nupogodi
Nupogodi
21 Mar 2016 22:18
What do you think about using double drywall (2 layers of 12mm (0.5 inches)) in the two children’s bedrooms upstairs, or is a single 20mm (0.8 inches) layer enough? Also, should we install sound insulation between the layers, or is regular insulation sufficient? (Our bedroom is on the ground floor)
Bauexperte
21 Mar 2016 22:22
Nupogodi schrieb:
What do you think about double-layer drywall (2x12mm (0.5 inch)) in the two children's rooms on the upper floor?
Why? Are you building in Chochstedt?
Best regards, Bauexperte
Nupogodi
21 Mar 2016 22:47
No, 68 km (42 miles) away. It was just a discussion with my site manager, and the question remained open. I don’t have any experience with this. It’s always the same question: single-layer without sound insulation is cheaper than the other option. How much cheaper, I don’t know yet. First, the question is whether anyone has regretted taking that risk.
Bieber0815
22 Mar 2016 07:12
I would double-layer the drywall (stability, crack prevention). Whether this significantly improves sound insulation is not so easy to say, as the topic is somewhat more complex. The wall must, of course, be insulated on the inside and decoupled from the exterior masonry. Will electrical outlets or light switches be installed there? How are the doors and door frames planned?
Nupogodi
22 Mar 2016 20:06
Light switches, power outlets – yes. I cannot yet say exactly how the frames will be fixed, as these details have not been discussed. Here, I trust the construction manager. They are very simple Prüm doors, with a few stainless steel inserts. From my point of view, double doors are much more stable; whether the insulation with soundproofing makes a significant difference, I cannot say.
Bieber0815
23 Mar 2016 22:20
For soundproofing, insulation contributes significantly more than double drywall layers.
