I have a rather specific question that’s been on my mind, especially concerning the long-term use of furniture: Does your IKEA KALLAX shelf unit start to fall apart after several years of use? In other words, do the joints become loose, the shelves unstable, or do you notice that the furniture piece isn’t as sturdy over time as it was initially?
Personally, I’ve handled my KALLAX quite carefully—no overloading or special stresses—but after about six years, I notice that the shelves slightly bend and some of the connections feel a bit “wobbly.” I’m curious whether this is a known issue or if it might be due to how I’ve used it.
Does anyone have advice on what might help maintain stability in the long run? Are there general experiences regarding whether the KALLAX tends to become prone to damage over time, or does it generally stay solid?
Looking forward to your feedback!
diManuela10 Dec 2019 09:47Hello NOAMGO,
thank you very much for your clearly formulated and detailed question!
From my many years of experience with KALLAX furniture, I can say that these pieces are quite sturdy, but they are not necessarily designed to withstand constant heavy loads. Especially the joints at the edges and the thinner shelves can bend over time if the unit is overloaded.
One suggestion would be to occasionally reinforce the shelves with small brackets or additional supports, if possible. Also, tightening the fasteners from time to time can be helpful.
A KALLAX unit should not fall apart easily as long as nothing extreme is placed on it. Have you checked whether the screws are still firmly tightened? If it wobbles, it is often because screws have come loose.
I have been using mine for several years as well, with no problems so far. Feel free to reach out if you have any more questions!
NOAMGO schrieb:
Does anyone have tips on what could help maintain stability in the long term?
In my experience, the stability of KALLAX mainly depends on how it is used. When loaded with heavy bookcases or many items, it can quickly become unstable.
Regularly tightening the screws helps. If something is really wobbly, it’s better to redo the screwing or use adhesive.
I’m glad you brought up this topic, NOAMGO, because I felt similarly uncertain and was almost disappointed with the lifespan of my KALLAX.
I think it’s important to emphasize this, as it’s often not just about the pure material quality, but also about expectations and appreciation for the space.
After a few years, my shelving unit became somewhat unstable, which initially confused me – I felt a bit disappointed because I assumed IKEA furniture would be sturdy enough for long-term use.
I then tried reinforcing it with small braces and some tools, and was able to improve its stability somewhat. From that perspective, I see it as a matter of how you treat the piece of furniture and how much care you put into maintaining it.
It would be great if we could also gather tips here on how to prolong the life of furniture.
NOAMGO schrieb:
Personally, I have been quite careful with my KALLAX, no overloading, no special stress
Here are some tips on how to improve the stability of KALLAX shelves over the years:
1. Check the connection technique: The shelves are often simply slotted or screwed together. Over time, screws can loosen slightly, so regular inspections are recommended.
2. Install reinforcement brackets: Small metal brackets on the back or inside add extra support.
3. Avoid overloading shelves: Do not heavily load all compartments, especially place heavy items on the bottom.
4. Use wood glue: Applying a drop of wood glue at some connection points can increase stability.
5. Keep the floor level: Uneven flooring causes lateral pressure, which weakens the structure.
Conclusion: KALLAX is sturdy but not solid wood. Long-term stability can be improved with small additional measures. Slight bending of the shelves after years is normal and not a weakness, but rather a characteristic of the material.
