ᐅ Does anyone have experience with epoxy sealing for KALLAX surfaces?
Created on: 19 Jun 2021 14:23
Lutzna
I am considering treating the surfaces of my IKEA KALLAX shelves with an epoxy resin coating. The main goal is to create a durable, glossy, and water-resistant surface that can withstand scratches and stains well.
Has anyone had personal experience with epoxy coatings on KALLAX or similar MDF-based furniture? I am especially interested in:
- How well does the resin adhere to the typically lacquered or melamine-coated surface?
- Are there any specific preparations that must be followed?
- What is the realistic curing time, and how durable is the surface in everyday use?
I look forward to hearing your experiences and tips!
I sealed my KALLAX with epoxy resin because I love the glossy finish and it’s very easy to maintain. 🙂
As mentioned here before, it’s important to lightly roughen the surface and remove any dust. In my experience, applying the resin in two thin layers works best – first pour a very thin coat, then apply another one after 24 hours.
The result feels almost like glass – completely smooth and extremely durable. The effort is definitely worth it if you use the right resin and technique. Good luck with sealing! 😉
I would like to add that when sealing KALLAX with epoxy, a clean working environment is essential, especially due to the dust-sensitive surface.
I also recommend checking before applying the resin whether the specific paint or coating on the KALLAX contains any solvents that could negatively affect the resin – this is rare but can cause etching or poor adhesion.
One more tip: position the shelf as level and still as possible during curing. This helps prevent runs and uneven layers.
Lutzna schrieb:
Have you experienced any issues with this, especially on such thin material as with KALLAX? That’s an interesting point. Epoxy generates heat during curing (exothermic reaction), and on thin MDF this could lead to warping.
I see this as a potential problem: when working with larger surfaces and applying several millimeters (fractions of an inch) of resin per layer, the heat could theoretically cause the MDF panel to swell or become wavy.
Therefore, I would recommend either applying only very thin layers or using a different sealing varnish.
Are there any specific experiences of someone who managed to keep KALLAX permanently stable after sealing it with a high epoxy resin usage?
Wow, what an exciting discussion here!
I sealed my KALLAX a few months ago with epoxy resin and am really satisfied! 🙂
I sanded with 320 grit. Also, I always cured the resin in a well-ventilated area, which helped reduce bubbling.
Highly recommend! The KALLAX now looks really elegant and is very durable. :-)
ODINFLO schrieb:Yes, that’s true. I actually applied several very thin layers — about 1-2 mm (0.04-0.08 inches) each — and there was no warping or discoloration.
Epoxy generates exothermic heat during curing, which could cause warping on thin MDF.
pikin schrieb:
To avoid heat buildup, apply thin layers in several steps. I will definitely do that, thanks for the tip!
Deandre schrieb:
check whether the specific paint or coating on the KALLAX contains any solvents Good idea, unfortunately I don’t have a testing device, but I will check the ingredients at IKEA.
nedagla schrieb:
I sealed my KALLAX with epoxy resin a few months ago and I’m very satisfied! That really encourages me, thanks a lot for the detailed feedback!
My next question: Does anyone happen to know a particularly suitable epoxy resin product for KALLAX or MDF furniture? That would be very helpful.
