ᐅ Does a conductive vapor barrier (aluminum) need to be grounded?
Created on: 24 Nov 2020 17:34
FragenaskerF
Fragenasker24 Nov 2020 17:34Hello,
we have a vapor retarder called Delta Reflex Plus, which has an aluminum intermediate layer. According to the manufacturer's information, this layer should shield 99% of electromagnetic radiation. As a complete layperson, this sounds to me like aluminum is conductive, and therefore there should never be any current reaching the vapor barrier, for example during roofing work using screws and a drill or when installing lighting/home technology.
Does anyone know about this?
Fragenasker24 Nov 2020 18:37Thank you for the response. But what if I want to install the lamp first and use a drill with screws (conductive) to penetrate the conductive coating—would I then not be grounded?
I might be completely missing something here. However, aluminum conducts electricity just as well as copper. If I drill through a live aluminum surface with a metal screw or accidentally come into direct contact with the aluminum surface using a metal object, wouldn’t the current pass to me without being able to flow away through an equipotential bonding connection? Or am I mistaken?
Fragenasker schrieb:
I wouldn’t be grounded then.But it is grounded through the screw, and why would the membrane carry current if it’s not connected anywhere? Ideally, you shouldn’t drill into the membrane at all.Fragenasker schrieb:
And if I drill through a live aluminum surface with a metal screw or somehow come into direct contact with the aluminum surface using a metal object in an unfortunate way, wouldn’t the current flow through me since it cannot discharge via an equipotential bonding? Mycraft schrieb:
The equipotential bonding is provided by the lamp itself, as long as it is connected properly according to regulations. Then you simply become the lamp – just not connected properly *SCNR*
