ᐅ Is it necessary to have LAN cables installed in the garage?
Created on: 11 Sep 2022 11:38
FrankChief
Hello
I wanted to ask what the essential use for a LAN connection in the garage would be?
Our electrician is reluctant to install a Cat cable in the garage.
He is charging twice as much as for a Cat cable inside the house (€500 in the garage) just for a Cat socket.
Why do you absolutely need LAN in the garage?
Wallboxes usually all support Wi-Fi anyway.
We are also planning to install photovoltaic panels later on.
Stefan001 schrieb:
What exactly needs to be connected in series 🤨
On the Ethernet side, nothing should require a "true" point-to-point connection. For us, there would have been the option (Zappi Harvey and Zappy HUB for the heat pump)
On Ethernet
xMisterDx schrieb:
Besides that, the company also has a VPN tunnel for the home office, so confidential data is encrypted at least once and not just stored unprotected on the hard drive...
And for online banking, there is two-factor authentication... Yes, that's true, but then the VPN password is stuck under the keyboard and the token for the 2FA is right next to it 😀
That’s how things work in practice ...
X
xMisterDx28 Nov 2022 15:31i_b_n_a_n schrieb:
Yes, that's true, but then the VPN password is under the keyboard and the token for 2FA is right next to it 😀
That's everyday practice ...Then it’s no longer a WLAN issue, but a lack of intrusion protection...
Guess how many people around me have roller shutters and KNX, but no security windows rated RC2 or higher 😀
O
Oberhäslich28 Nov 2022 19:49What do you do if the garage is built later? Just lay the cables outside and leave them exposed? The location is not yet decided.
xMisterDx schrieb:
What do you think, how many people around me have roller shutters and KNX systems, but no security windows rated RC2 or better 😀They don’t help with Ytong either if someone just cuts an opening next to the window with a cold chisel :p :p :pX
xMisterDx28 Nov 2022 21:52Dogma schrieb:
They are useless with Ytong if you just cut an opening next to the window using the spike tool :p :p :pBut only for the plaster layers. For everything underneath, use a damp finger; that makes less noise.
Oberhäslich schrieb:
What do you do if the garage is built later? Just lay the cable outside and leave it exposed? The location is not clear yet. Exactly. Lay the underground cable and leave it long enough to avoid splicing. Just don’t terminate it on a patch panel or connect it to the switch yet.
