ᐅ Design of Baseboards: Transition Between Hardwood Flooring and Tile
Created on: 28 Dec 2015 09:37
Kaffeebart-1
Kaffeebart-1
28 Dec 2015 09:37
I can’t find a suitable section for my question, so I’ll just try here under Flooring — it could also fit under Tiles.
We are currently considering how to design the baseboards on the ground floor.
Here is the issue:
In the living/dining area, we will have oak parquet flooring, and in the entrance area, dark tiles (light black/anthracite). Unfortunately, the transition between these two materials is along a wall in the entrance area (not at a corner). See the graphic — the separation of the materials corresponds to the red line (wood = brown and tile = black).
How would you handle the baseboards in the entrance area? Should we use a tiled baseboard or continue with the wooden baseboard from the living area? If you would change the material, exactly where would you place the transition? I can’t quite imagine switching the baseboard type on the same wall.
Thank you very much for your opinions.
Luca-1
31 Dec 2015 08:18
Use transition strips; I have them as well. I installed them about 3.5 years ago, and they have held up really well so far.
Kaffeebart-1
31 Dec 2015 09:27
Luca schrieb:
Just use transition profiles, that’s what I have as well.
I only know those for flooring, not for baseboards.
Could you please post a picture of that?
Then I can get a general idea of how it looks visually.
Thanks
Marcel-1
6 Jan 2016 05:18
There are aluminum strips like that, and it should work as well. I haven't used them myself yet, but it's an idea I have.
seiler-1
19 Jan 2016 07:27
I agree, because I wouldn’t have any other idea either. Otherwise, it wouldn’t look right. With the curved design, it doesn’t look the same immediately, and the room feels different. I can easily imagine that.
Hannes1983-1
10 Feb 2016 09:29
That would have been my suggestion as well, to make it curved. Especially with this material transition, it is difficult to find the right baseboard / skirting board. So the advisor from your tile supplier has a good idea.
