ᐅ Cost of a U-shaped staircase with a double return and no intermediate landing
Created on: 13 Jun 2016 10:18
Peanuts74P
Peanuts7413 Jun 2016 10:18Hello,
Is there a tiler here who can roughly estimate the cost of installing tiles on a U-shaped staircase (double winding without an intermediate landing) using the thick-bed method?
I am asking about the labor cost only. Would the labor cost be higher if a stair nosing profile is installed at the front edge, and if so, by how much?
Sebastian7913 Jun 2016 10:25It will cost you around 1000 euros without materials...
Polle 196715 Jun 2016 12:32Hello
I don't want to unsettle you, but have you considered a U-shaped staircase with tiles?
When we built our first house, we were advised against tiling a U-shaped staircase because the grout lines tend to create a visually busy effect on this type of staircase.
Take a close look at U-shaped staircases with tile coverings before you decide, so you don't regret it later.
Peanuts7415 Jun 2016 12:38Maybe I’m an exception, but I find the pattern quite interesting right now. And since the tiles are 30 x 60 cm (12 x 24 inches), the grout lines aren’t too prominent either...
Polle 196715 Jun 2016 12:47Ok, I have absolutely nothing against joints, but on your staircase, none of them are aligned.
Peanuts7423 Jun 2016 11:41Polle 1967 schrieb:
ok, I have absolutely nothing against joints, but there isn’t a single one in line on your staircase.How do you come to that conclusion???
