ᐅ Colors in Floor Plan / Section of a Semi-Detached House
Created on: 13 Oct 2021 07:33
Fabian_81
Fabian_81
13 Oct 2021 07:33
what do the colors in the floor plan/section mean: green/red? This is a solid masonry semi-detached house built in 1993.
See the pictures (the topic of the wooden balcony led us to this question).
Thank you
Fabian
Schnittzeichnung eines geneigten Dachs über Holz-Balkon mit roter Stütze und Geländer.
Grundriss eines Apartments: rote Innenwände, grüne Außenlinien; linkes Bad, rechtes Zimmer.
Scout
13 Oct 2021 09:39
Probably:
Green walls = structurally necessary.
Or in timber frame construction:
Green = wood
Red = masonry or drywall
13 Oct 2021 10:04
Show everything, not just a part – it’s like a puzzle…
11ant13 Oct 2021 13:44
Scout schrieb:
Probably:
In practice, I haven’t observed any consistent color-coding standards, and certainly not any coding based on structural relevance. What I often see is a distinction between masonry (often red), (reinforced) concrete (often light green), and lightweight construction (occasionally blue).
Green = wood
Red = masonry or drywall partitions
I find that even less likely here.
Scout
13 Oct 2021 13:54
In our plans, dashed lines indicate concrete, hatching represents sand-lime bricks, and load-bearing walls are shown in red.
By the way, you can find all of this in the legend on the plan :p
11ant13 Oct 2021 14:02
Scout schrieb:
In our plans, dashed lines represent concrete, hatched areas are calcium silicate blocks, and load-bearing walls are marked in red.
So, does that mean calcium silicate blocks are load-bearing when hatched and red?
Scout schrieb:
By the way, you can find all this in the legend on the plan :p
Ah yes, legends—they seem to have fallen out of fashion, just like signaling before turning.
