ᐅ Central ventilation system extremely expensive.
Created on: 7 Sep 2015 07:42
daniels87
daniels87
7 Sep 2015 07:42
Hello!
We currently have a general contractor (GC) in the running who we really like and who has a good reputation in our area.
However, when I asked about a controlled ventilation system, I was shocked. They quoted around €14,000 (about $15,000)! For 133 sqm (1,433 sq ft), I find that almost outrageous.
A decentralized solution with four units is supposed to cost €8,000 (about $8,600).
My plan was actually to have the ventilation system designed by a specialized company (for example, the manufacturer or a ventilation expert) and to handle the installation myself with a heating engineer friend. Even if it requires reinforcing the ceiling and adding a few ducts in the walls, €14,000 as a non-professional just doesn’t make sense to me.
The GC insists that if the ventilation system is removed, the entire heating/plumbing trade would have to be removed as well. I don’t understand the connection, but I would prefer not to do that.
What do you think about this statement?
Daniel
Legurit
7 Sep 2015 08:16
What exactly will be installed?
What type of heating system will be used for the central installation?
For decentralized systems, the coordination between trades is not clear to me.
In our case, the general contractor handles the decentralized ventilation, and we subcontract the heating and plumbing work ourselves. It’s unclear whether there is any technology that would prevent this approach here...
Always keep in mind that even when self-managing, the electrical trade is also involved (power supply and control of ventilation, thermostats, distribution panels) – so clarify this in advance.
Has the contract already been signed?
Häuslebau3r7 Sep 2015 08:40
Good morning Daniel,
do you happen to know the manufacturer of the controlled residential ventilation system? That might help some experts in the forum to better assess the situation. Unfortunately, I cannot assist you with the price or whether it is expensive or not. But as mentioned, there will surely be users here who can help.
Regarding the trade involved, my understanding is that if you decide to carry out some work yourself, everything related to that automatically becomes your responsibility. In your case, this probably applies to the ventilation system in connection with the heating/plumbing trade. For a central system, the connection with those trades makes sense to me, but not for a decentralized system. After all, who would be liable in case the ventilation system is not installed properly? You might find additional information under the term “retroactive self-performance.”
Bauexperte
7 Sep 2015 11:46
Hello Daniel,
daniels87 schrieb:
Only when I asked about a controlled residential ventilation system did my jaw drop. I have to expect around €14,000! For 133 sqm (1430 sq ft) I find that almost outrageous.
Could it be that you were offered a combined unit – air-to-water heat pump plus ventilation?
daniels87 schrieb:
A decentralized solution with 4 fans is supposed to cost €8,000.
With a breakthrough in every room? It’s also possible to do it floor-by-floor, and then you’d be looking at around €9,500.
daniels87 schrieb:
But the general contractor says that if the ventilation system is removed, the entire heating/plumbing trade has to be removed as well. I don’t understand the connection, but I don’t actually want that.
I can understand it because you would be directly affecting the plumbing trade; even more so if you answered my initial question with "yes."
Saving by using subcontractors is reasonable only if the provider has fulfilled their contract. Anything else leads to problems that anyone with common sense would want to avoid. At least in the setup with a homeowner and a general contractor.
Best regards, Bauexperte
daniels87
7 Sep 2015 14:04
First of all, thanks for the numerous replies!
We had an initial discussion, and we expect to receive a quote soon. The standard heating system is gas/solar. An air-to-water heat pump with underfloor heating in the ground floor, upper floor, and basement hallway is expected to cost around 9,000 € (approximately 9,900 USD) extra, which I found to be reasonable.
The additional controlled ventilation system with heat recovery is said to cost 14,000 € (about 15,400 USD). I can only provide the exact technology once the quote is available.
The decentralized units also include heat recovery, so I assume these are individual devices.
Bauexperte
7 Sep 2015 14:09
Hello Daniel,
daniels87 schrieb:
The standard heating system is gas/solar, a air-to-water heat pump with underfloor heating on the ground floor, upper floor, and basement hallway is supposed to cost about €9,000 (around $9,700), which I found fair.
Wow – if the surcharge for the air-to-water heat pump compared to the standard system already requires this additional cost (it should be nearly cost-neutral; even in Bavaria), then the following paragraph
daniels87 schrieb:
The additional controlled residential ventilation with heat recovery is said to cost €14,000 (around $15,000).
must actually refer to the pure costs of the controlled ventilation system and in my opinion are unreasonable; even in Bavaria!
My advice: look for another supplier
Regards, Bauexperte
