ᐅ Which manufacturer should I buy the heat pump and ventilation system combination from?
Created on: 20 Oct 2025 00:16
O
OhropaxGood evening,
Is it better to buy the heat pump and the central ventilation system from the same manufacturer, or is that not a good idea? Which manufacturers would you recommend? According to my research, Stiebel Eltron and Wolf are considered "good" manufacturers, or is there perhaps a "hidden gem"?
nordanney20 Oct 2025 07:49Ohropax schrieb:
Is it better to buy the heat pump and the central ventilation system from the same manufacturer, or is that not a good idea? That’s the same question as asking whether the iron should be from the same manufacturer as the TV. They have nothing to do with each other.
Do you plan to purchase and install them yourself, or what is the reason for the question?
nordanney schrieb:
It’s the same question as whether the iron should be from the same manufacturer as the TV. They have nothing to do with each other.
Do you want to buy and install them yourself, or where does the question come from? I have a plot of land and plan to build in 2026. At the moment, I am still gathering information.
I have read that it’s best to get the heat pump and the central ventilation system from the same provider because then you have one technician and one app as the main point of contact. Isn’t that a good approach? I also saw that, for example, Stiebel Eltron offers buffer tanks and domestic hot water storage tanks. Essentially, I’m asking about possible synergies. Of course, I don’t know how good the individual components are or if I might be overlooking something or becoming too dependent on one manufacturer. What do you think?
nordanney20 Oct 2025 11:10Ohropax schrieb:
I have read that it’s best to get the heat pump and the central ventilation system from a single supplier, so you have one technician and one app as your point of contact. Isn’t that a good approach? I also saw that, for example, Stiebel Eltron offers buffer tanks and domestic hot water tanks. Basically, I’m asking about possible synergies. But of course, I don’t know how good each component is or if I might be missing something and becoming too dependent on one manufacturer. What do you think? Personally, I’m not a fan of a one-size-fits-all solution. I’ve also never read that it’s best to install everything "from a single source."
Typically, heat pumps and mechanical ventilation with heat recovery are two separate systems. It doesn’t really matter—many excellent heat pump manufacturers do not offer mechanical ventilation units, and vice versa. So the selection is naturally more limited. I’m also not a fan of combined units—what do you do if the heat pump breaks down? Do you need a whole new combined system? Keep it simple.
Ohropax schrieb:
I also noticed that, for example, Stiebel Eltron offers buffer tanks and domestic hot water tanks. Basically, I’m asking about synergies. There aren’t any.
P.S. The manufacturer of a heat pump or mechanical ventilation system is one of the last things you should be worrying about during the house construction process—it’s probably number 137 on your to-do list.
nordanney schrieb:
Personally, I’m not a fan of the all-in-one solution. I’ve never read that it’s best to have everything installed "from a single source."
Usually, a heat pump and a mechanical ventilation system with heat recovery are two separate units. It doesn’t matter—many excellent heat pump manufacturers don’t offer mechanical ventilation systems, and vice versa. So, the options are already quite limited. I don’t like combined units either—do you really want a new combined unit if the heat pump fails? Keep it simple.
Such a thing doesn’t exist.
P.S. The manufacturer of a heat pump or mechanical ventilation system is one of the last things you should worry about when building a house. That’s more like item 137 on the to-do list.Ok, keep it simple has convinced me! Thanks for that.What would be the top 5 priorities when building a house?
nordanney20 Oct 2025 13:25Ohropax schrieb:
What would be the top 5 priorities in house construction? Space requirements, living situation, daily routines, floor plan, house orientation, budget – these are roughly my first five points.
Then come noise considerations (internal/external), lighting, shading, ceiling heights, and the plot of land. Technical questions (ground-source heat pump, air-to-water heat pump, air-to-air heat pump, electrical systems/automation), heating design for underfloor heating, and similar aspects.
Eventually, materials and the plot itself: type (preferably parquet or tiles as an example, interior doors) or colors. Finally, the building materials themselves (unless noise protection or a building permit/planning permission or design regulations specify requirements that take priority).
