ᐅ Is it possible to treat MALM furniture with spray paint?
Created on: 24 Jul 2022 19:07
Guenno
Guenno
24 Jul 2022 19:07
I am currently considering whether I can use spray paint on my IKEA Malm furniture to give it a new color and a more durable surface. I am particularly interested in whether the spray paint adheres well to the melamine coating or the particleboard and if there are any special preparatory steps to follow in order to achieve a long-lasting and even finish.
Does anyone have experience with this combination? For example, which types of spray paint are suitable, whether a primer is necessary, and the best approach to avoid peeling or uneven surfaces.
Thanks in advance for your tips and advice!
Emery
24 Jul 2022 20:13
Hello Guenno,
In principle, it is possible to treat MALM furniture with spray paint, but there are important details to consider. MALM is usually made of particleboard with a melamine coating, which is very smooth and has low absorbency. This makes adhesion of spray paint challenging unless the surface is properly prepared.
It is important to first roughen the surface with fine sandpaper (e.g., grit 240). This will texture the smooth surface and help the paint adhere better. Then, it is best to apply a special adhesion-promoting primer suitable for plastics.
For the spray paint, I recommend acrylic paints designed for furniture, as they remain flexible and are less prone to cracking. When painting, apply several thin layers and allow each layer to dry thoroughly.
Make sure to work in a well-ventilated area and follow the product instructions carefully.
Best regards!
mopra42
25 Jul 2022 08:42
Spray paint on MALM? It works, but:
1. Sand thoroughly (240 to 320 grit)
2. Apply a primer
3. Build up thin layers of paint patiently
Do not apply paint directly, or it will peel off quickly.
Palenar
25 Jul 2022 20:55
Hello Guenno,
to cover the topic thoroughly, here is a detailed guide to clarify how you should proceed if you want to spray paint your MALM furniture:
1. Material Analysis: MALM furniture has a smooth melamine coating. This surface is quite resistant to mechanical impact but also very smooth, which makes paint adhesion difficult.
2. Preparation:
- Clean the surface thoroughly with a degreasing agent to ensure no grease or dust affects the outcome.
- Sanding: A fine sanding with 240-grit or finer sandpaper is essential to roughen the surface. I recommend a sanding sponge because it conforms well to the shape.
3. Priming:
- A special plastic-based adhesion primer is, in my experience, very helpful as it improves paint adhesion.
- Make sure the primer is suitable for melamine or plastics. Sometimes the paint manufacturer offers appropriate primers.
4. Paint Application:
- Apply several thin coats, allowing each to fully dry (at least 12 hours, depending on the product).
- Also ensure good ventilation, as otherwise hardeners or solvents may not fully evaporate.
5. Finishing:
- If needed, you can lightly sand the final coat with very fine sandpaper (e.g., 600-grit) and apply a clear lacquer layer for protection.
Pitfalls:
- Avoid working impatiently and applying thick paint layers, as this can cause cracking or bubbling.
- Without sufficient preparation, the paint will most likely peel off the melamine coating.
I would also be interested: Are you planning to completely change the furniture color or just refresh it? This can influence the choice of products.
Z
zarlu
26 Jul 2022 12:37
Palenar schrieb:
Pitfalls: Avoid impatient work and applying thick layers of spray paint, as this can cause cracking or blistering.
I agree. Honestly – who expects IKEA furniture with spray paint to become high-end pieces over time?
Sometimes it’s more of a fun experiment. Spray paint is better suited for smaller surfaces or DIY crafts, rather than large furniture surfaces that are used daily. If you want long-term durability, it will quickly become obvious how fast the paint wears after even the first time moving the furniture.
Emery schrieb:
Acrylic paints designed for furniture remain flexible and don’t crack as easily.
Yes, although I’d personally prefer professional coatings or films when it comes to MALM.
My point is: just spray painting doesn’t automatically mean better results. It can create an illusion that you’ll have to fix later. More important than paint quality is surface preparation and the intended use.
Good luck if you decide to try it 😉 Maybe others will share their practical experiences as well.
