ᐅ Broadband connection / TV, radio, and LAN in every room?
Created on: 8 Oct 2018 21:49
Gotthilf
Unfortunately, I am a complete beginner regarding the above-mentioned topic and quite uncertain:
We are currently building our house, which will be connected via a broadband connection from KEVAG Telekom (TV, radio, internet, telephone). I assume the main connection point will be located in the utility room (house without a basement).
In every living area, the following connections should be possible:
- TV / radio
- LAN
- Broadband modem (or do I only need this in the utility room?)
As part of the construction work, all living rooms are to be equipped with Cat 6 network cables (supporting 10 megabits to 1 gigabit), arranged in a star topology running to one chosen room (most likely the utility room).
Do I need any cables besides the Cat 6 network cable in a room to have TV, radio, and internet LAN connections there, for example, separate LAN cables?
What specific types of wall outlets should I have installed in the rooms?
I kindly ask for clear explanations. I am not young anymore and have no knowledge of this subject.
Thank you very much!
Gotthilf
Traumfaenger
9 Oct 2018 22:24
Deliverer schrieb:
It seems Traumfaenger has confused something here. The broadband modem does not necessarily have anything to do with Wi-Fi. Regardless of what the device is ultimately called (modem, router, connect box),
@Deliverer : You are right, thanks for the clarification of terms. Indeed, a modem and a Wi-Fi router can be two physically separate devices with different functions. I only use it as a combined device now, but it doesn’t have to be that way.
Deliverer schrieb:
These make Wi-Fi unnecessarily slow. Instead, it’s better to connect an access point (placed strategically in the house) by cable to the aforementioned switch.
Yes, I agree completely here as well:
Traumfaenger schrieb:
In the past, wired transmission capacity was usually higher than wireless (Wi-Fi).
In the future, I will only use Wi-Fi for phones / iPads and for a guest network. That’s why all cables are CAT7 (currently still with CAT6 wall outlets, @Fuchur). Your solution with access points is definitely more efficient than a Wi-Fi repeater, I hadn’t thought of that. Thanks for the tip.
