ᐅ BILLY Shelving Units Bowing Under Loads – How Can I Prevent This?
Created on: 3 Apr 2023 09:23
TeddyteHello everyone, I have a problem with my Billy shelves: the shelves bend under the weight I have placed on them. Specifically, I have about 15kg (33 lbs) distributed on each shelf, which shouldn’t be too much for the unit. Still, there is a noticeable sagging in the middle of the wooden shelf. My question is: how can I prevent the Billy shelves from permanently bending under load? Are there practical solutions that don’t require major modifications, perhaps with additional supports or a different way to distribute the weight? I would also like to know if there are materials or technical tricks that can be used to make these shelves more durable and stable. Thanks for your feedback!
Hello Teddyte, I completely understand how frustrating it is when a shelf sags, even though you don’t want to overload it. I had a similar experience with my BILLY shelves – the load wasn’t extreme, yet the wood eventually gave way. What helped me was actually adding extra slats underneath the shelves, which I secured with small screws. I consciously avoided putting too much strain on the shelf, but the additional support made a big difference.
It might also help to distribute the weight more evenly and place especially heavy items across several shelves instead of stacking everything on one. I also wonder if IKEA might have an issue with the material thickness – perhaps the shelves simply aren’t designed for very heavy loads if they keep sagging like that.
What about your shelf thickness? According to the product description, how much weight are they actually meant to support? Before you start making modifications, that might be important information.
Teddyte schrieb:
How can I prevent BILLY shelves from permanently sagging under load?
To effectively prevent sagging of the BILLY shelves, it is important to consider the load capacity of the chipboard panels used. According to the manufacturer, the shelves are designed for a maximum static load of about 13-15 kg (29-33 lbs) per shelf, which represents the limit for many everyday uses.
The issue usually stems from the relatively thin MDF or chipboard (approximately 16 mm (0.6 inches)) bending under load, especially over larger spans of around 80-90 cm (31-35 inches). A practical and proven solution is to add reinforcements underneath, such as aluminum profiles, wooden battens, or U-shaped metal brackets, which are mounted directly on the shelf edge. This significantly improves the bending resistance of the shelves.
Additionally, I recommend distributing the load as close to the side panels as possible rather than placing it entirely in the middle. This reduces the leverage effect.
Last but not least: alternatively, shelves can be replaced with thicker or specially reinforced boards (e.g., plywood). These have a significantly higher load-bearing capacity.
Thierryzar3 Apr 2023 14:09In short: You can counteract this by using battens or metal brackets under the floors. It is also advisable to distribute the weight more evenly and avoid placing very heavy items on a single floor area.
Hello Teddyte, this is a common issue with the BILLY shelves because their shelves are made from thinner particle boards that tend to sag under heavier loads. I recommend, in addition to the already mentioned metal or wooden strips as supports, to install them properly: screw the strips along the entire length of the shelf – otherwise, it won’t be very effective.
Also, try to distribute the weight evenly and place lighter items more towards the center, while heavier objects should be closer to the side panels.
If you have some DIY skills, you can also add extra supports, like small intermediate feet, to support the shelves from underneath. This way, the load is transferred directly to the floor and not only to the thin shelves.
I agree, that is really very important. Good luck!
boelnu schrieb:
Maybe it also helps to distribute the weight better and spread especially heavy items across several shelves instead of stacking everything on just one.
Overall, interesting contributions, but I think we should also critically examine how IKEA defines the maximum load capacity.
That sounds plausible, but details about dynamic loading or the type of load (e.g., distributed load versus point load) are often missing. Therefore, this information is not always reliable.
Apart from that: Using metal strips or other reinforcements makes sense. However, it’s important not to forget that the attachment points of the shelves themselves are weak spots – the reinforcements should not only stabilize the shelf board but also include checking and possibly reinforcing the connections within the shelving unit.
Furthermore, I wonder: What about humidity and indoor climate control? Particleboard can swell and lose stability as a result. Does anyone have experience with this? Perhaps this is an underestimated factor affecting sagging.
A general recommendation: For storing heavy loads, it might be worth considering more robust shelving units or replacing the BILLY shelves with plywood boards, as Lorukeo suggested.
Lorukeo schrieb:
According to the manufacturer, the shelves are designed for a static load of about 13-15 kg (29-33 lbs) per shelf
