Some time ago, I bought a Billy bookshelf from IKEA, but I noticed that the doors I installed are slightly warped. This mainly shows because they don’t close properly and look uneven in some areas.
My question is: What is the best way to straighten these warped doors?
I have considered whether treating them with heat might help or if simply adjusting the hinges would be enough, but I’m concerned that I might cause more damage. Perhaps someone has knowledge of material properties or experience with similar cases.
I would appreciate any tips, especially on how to avoid damaging the surface and what should definitely be avoided.
Good morning!
A quick update on my idea with the steaming towel: I tried it myself, but only for a very slight bending. In your case, with 3-4 mm (0.1-0.15 inches), I would also advise against it – the material would be too much affected.
A small tip on the side: If the shelf is placed in a more humid location, the humidity could worsen the problem. You can also take this into account when straightening; it’s best to work in a dry environment.
Thank you for all the helpful contributions!
Today, I will remove the doors, lay them flat on an even surface, and weigh them down. I will completely loosen the hinges before reinstalling and then readjust them.
If this does not lead to sufficient improvement, replacing the doors seems to be the most reasonable step, as a 3-4 mm (0.1-0.16 inches) warp does not sound like something that will stay straight in the long term.
I have also noted the advice regarding humidity, as the system is located in the basement, which probably explains the issue.
I will provide an update once I have tried these measures.
