ᐅ Protecting Softwood Shelving – Which Types of Finishes Are Recommended?
Created on: 2 Feb 2021 10:17
lepuro
I recently bought a Billy shelf made of softwood and want to protect it well so that it stays looking nice and remains durable for a long time. Now my question is: Which types of varnish are recommended to optimally protect a Billy shelf made of softwood?
It is important to me that the varnish not only protects against moisture and dirt but also preserves the natural appearance of the wood or at least does not alter it too much. Additionally, if possible, I would like to use sustainable products.
What are your experiences with varnishes that are especially suitable for softwoods like pine or spruce, particularly for furniture that is heavily used in everyday life? Are acrylic varnishes better, or would polyurethane be preferable? And what about the application—does the shelf need to be primed beforehand?
I look forward to your expert recommendations and tips on protecting a Billy softwood shelf—what types of varnish do you recommend?
kibutar
3 Feb 2021 09:17
Hello lepuro,
To professionally protect your Billy shelf made of softwood, you should approach the surface treatment as a multi-step process. Let me explain it step by step:
1. Surface preparation: Start by sanding the wood with 120-grit and then 220-grit sandpaper to create a smooth, dust-free surface.
2. Primer: Apply a low-solvent primer based on polyurethane or acrylic. This seals the wood, smooths the surface, and improves the adhesion of subsequent layers.
3. Intermediate sanding: After drying, lightly sand the primer with very fine sandpaper (e.g., 320-grit) to remove any unevenness.
4. Topcoat: You can choose between water-based acrylic paints and polyurethane coatings.
- Acrylic paints are more environmentally friendly, have good flexibility, and preserve a natural wood appearance. However, they are somewhat less durable.
- Polyurethane coatings offer better protection against scratches and wear, cure to a hard, robust surface, and are better suited for shelves subjected to heavy use.
5. Working environment: For optimal drying, paint at 20-25°C (68-77°F) with around 50% relative humidity.
6. UV protection: If the shelf is exposed to sunlight, a coating with a UV blocker is recommended to prevent yellowing.
Domau0 schrieb:
"Zwischenschliff mit feinem Schleifpapier (z.B. 220er Korn) zwischen den Lackschichten"
You should definitely follow this advice, or the surface quality will suffer.
I hope this gives you a clear overview. Which coating products have you considered so far?
Domau0
3 Feb 2021 11:26
kibutar schrieb:
"Intermediate sanding with fine sandpaper (e.g., 220 grit) between coats of varnish"\
Exactly, and to confirm sonpar’s point: A matte or satin acrylic varnish is what I would recommend for softwood furniture to preserve the natural surface.
At the same time, I would add that temperature and humidity during varnishing should not be underestimated. Moisture can especially cause issues like blistering with water-based varnishes.
Are there any thoughts yet regarding the appearance? Do you prefer the shelf to look naturally light, or are you planning to use a stain or paint?
lepuro
4 Feb 2021 08:53
Thank you all for the many helpful contributions and suggestions!
The shelf will mainly be placed in the living room, so normal room temperature and humidity. It won’t be exposed directly to sunlight, so UV protection is not necessarily required, but some resistance to scratches is definitely advisable since there are children in the household.
Therefore, I am leaning toward a water-based acrylic clear coat with a matte or satin finish, as I want to preserve the natural look of the wood as much as possible.
I am planning to get the appropriate primer at the same time. Are there special primers for softwood, or is any acrylic primer sufficient?
Also, how many layers of paint should I apply at a minimum to ensure good durability, especially with daily use?
Looking forward to your advice!
