ᐅ Are there reinforced back panels available for BILLY shelves?
Created on: 18 Apr 2017 20:07
JUGAU
JUGAU
18 Apr 2017 20:07
I am currently looking into stabilizing BILLY bookcases and wondering if there are any specially reinforced back panels available for BILLY units. I have some models that I would like to use for heavier items and am unsure whether the standard thin particleboard back panels are sufficient or if there is an official reinforced version that significantly improves stability. Does anyone have experience with this or know if IKEA offers such stronger back panels separately?
Perhaps someone also has tips on how to reinforce BILLY back panels if original parts are not available. Thanks in advance!
U
USKIPA
18 Apr 2017 20:23
There are no official reinforced back panels from IKEA for BILLY. Most users recommend reinforcing the back panel yourself with additional wood panels or MDF.
O
olivernu
18 Apr 2017 21:15
That is correct; IKEA only provides the thin particleboard back panels. If a stronger solution is needed, you can either have a custom back panel cut from plywood or MDF, or additionally install a metal back rail. The latter improves load capacity and prevents warping.
Trine
19 Apr 2017 08:44
If a more stable back panel is desired, simply have a plywood panel or a 6 mm (1/4 inch) MDF board cut to size and replace the original back panel. This is easy to do and provides much greater stability.
JUGAU
19 Apr 2017 09:10
Thanks for the tip! Could you possibly specify how thick the MDF or plywood back panels should be at minimum to achieve a noticeable improvement in stability? Also, are there any special considerations when attaching the back panel to ensure it holds properly and prevents the shelf from tipping over?
bijo54
19 Apr 2017 09:57
I used MDF with a thickness of 6 mm (1/4 inch). It is important that the back panel is fixed on all sides, including the top and bottom. Drive screws into the cabinet sides – not just into the strips. This ensures the shelf remains very stable.
