ᐅ Are there any guides for combining the Ikea Hemnes series with other furniture ranges?
Created on: 16 Oct 2022 10:07
Talen
Talen
16 Oct 2022 10:07
Hello everyone, I am currently working on designing my apartment and considering combining the Ikea Hemnes range with furniture from other series. I am wondering if there are any reliable guides or proven recommendations on how to combine Hemnes furniture with other Ikea series in an aesthetically pleasing and functional way. I am particularly interested in advice on color and material compatibility, as well as practical tips for assembly and spatial effects. Are there any experiences you could share, or perhaps even detailed instructions that provide a structured overview of how to effectively pair Hemnes with other series?
FeAndreas1
16 Oct 2022 11:43
Hello Talen, your question is very interesting and actually not that easy to answer, since Ikea deliberately designs many collections with their own unique design language. The Hemnes series is characterized by its traditional country-style look with wood effects and fairly solid frames, which visually sets it apart from many more modern series. However, there are definitely options for mixing and matching if you consider a few aspects.
First, regarding color and materials: Hemnes usually comes in clear white or wood tones with visible grain, which pairs well with neutral, matte surfaces from series like Kallax or Bestå, which are often smoother and more modern. It is important to either choose similar shades or intentionally create contrasts.
In terms of assembly, keep in mind that Hemnes furniture is often a bit heavier and more robustly built, so not all fasteners and connectors from the other series are compatible. I recommend using spatial arrangement solutions instead of direct connections—such as placing furniture close together without physically attaching them—to maintain flexibility later on.
As a tip: if you plan to combine open shelves or sideboards from Hemnes with modular elements from another series, it’s worth comparing exact dimensions beforehand and, if possible, placing the furniture side by side in the store. Where exactly do you want to combine them? That would help to give more specific advice.
jeff65
16 Oct 2022 13:15
FeAndreas1 schrieb:
First, regarding colors and materials: Hemnes usually comes in clear white or wood tones with visible grain, which works well with neutral, matte finishes from series like Kallax or Bestå, which are often smoother and more modern.
This is an important point. I would add that when combining Hemnes with other series, the contrast in style should be intentional. If you’re aiming for a cohesive look, it’s essential to carefully match surface texture, color warmth, and design elements. With Hemnes, too stark differences can quickly create visual tension in the room.
In practice, it helps to compare samples in person and assess wood samples at home under different lighting conditions. You should also check the internal dimensions of the carcasses, especially if the furniture needs to function together later on.
GALENKU
16 Oct 2022 14:27
I often combine Hemnes with Bestå. It works well if you pay attention to the colors: white or birch for Hemnes and similar shades for Bestå. Just place the units next to each other; it’s better not to screw them together.
semuneo
17 Oct 2022 09:33
Talen schrieb:
I am particularly interested in advice regarding color and material compatibility as well as practical tips for assembly and spatial effects.
I completely understand—that was a question I had myself when I furnished my apartment with Hemnes. It can be overwhelming at first, especially if you want to combine Hemnes with more minimalist series like Malm or Pax. I spent a long time experimenting by initially mixing small furniture pieces and observing what harmonized and what didn’t.
From my experience: it’s best not to change too much at once, but rather to choose individual elements from complementary series that visually create a calm interplay. For assembly, I recommend staying flexible and avoiding trying to mechanically connect different series too rigidly. Instead, arrange the furniture so that each series retains its own character. This adds personality to the room and reduces stress during reorganization.
And very importantly: take your time planning and consider how you will use the furniture in daily life. How often will you rearrange? Which functions are important to you? This way, you can avoid making costly mistakes.
