ᐅ Are there Ikea PLATSA furniture models designed for the bathroom?
Created on: 25 Oct 2023 14:07
V
valerioloV
valeriolo25 Oct 2023 14:07I am currently wondering if Ikea offers any PLATSA furniture models specifically designed for use in bathrooms. I find the PLATSA system quite flexible in general, but since a bathroom is a wet area, I am curious whether Ikea has suitable options in their range that are water-resistant or at least appropriate for humid environments.
Does anyone know of specific products or have experience with using PLATSA elements permanently in a bathroom?
I would like to know:
- Are there any special versions or additions within the PLATSA range that are optimized for bathrooms?
- What about materials and finishes that can withstand moisture?
- Has anyone already installed PLATSA bathroom furniture and can share practical insights?
This question is important to me because I am looking for a modular, flexible solution that I can customize individually without having to switch to completely different bathroom furniture.
Hey valeriolo!
That’s a great question – I installed a small bathroom using PLATSA modules a few months ago and I’m really happy with it! 🎉 The units aren’t specifically designed as bathroom furniture, but the surfaces are durable and fairly moisture-resistant. Of course, you need to make sure they don’t get constantly wet (so not directly inside the shower!), but they work great for cabinets or shelves next to the sink.
- The doors are usually coated with melamine resin, which protects them from moisture.
- In my case, the edge sealing also holds up well.
Tip: If you want extra security, you can treat the furniture with a clear spray lacquer – I did that and it’s invisible but provides additional protection!
So, don’t hesitate, give it a try! The flexibility is fantastic, and you can always modify or expand it later. Good luck with your renovation! 🙂
Regarding the question of whether Ikea offers PLATSA furniture models for the bathroom, I would like to explain some technical details that may help with the assessment.
Currently, Ikea does not offer any PLATSA variants specifically designated as bathroom furniture. The system is based on particleboard with melamine resin coatings, which provide some water resistance but are not considered waterproof.
The typical challenges with bathroom cabinets are:
- Constant exposure to moisture (steam, splash water)
- Temperature fluctuations
- Potentially high humidity
PLATSA elements are generally designed for living spaces with normal humidity levels. This means:
- Floors, backs, and edges are not specially sealed against water ingress.
- Additional sealing would be advisable to prevent minor moisture exposure.
In practice, this means the furniture is suitable for bathroom areas that are not heavily exposed to water (e.g., dry walls or above the toilet).
I would like to know more about your bathroom specifics:
- Are there direct water sources (shower, bathtub) in close proximity to the furniture?
- What are the humidity levels and ventilation options?
With this information, it would be easier to evaluate whether using PLATSA for your project is appropriate or if a dedicated bathroom furniture system would be a better choice.
I would like to raise a critical point here. Many users install PLATSA in bathrooms without considering the possible long-term effects.
In my view, this is the key issue. Just because something works in the short term does not mean it’s suitable for continuous use. A melamine resin coating can tolerate minor moisture, but over months or years, swelling can occur at unsealed edges.
Another point:
- Mold protection is also important for bathroom furniture, which is not standard for regular PLATSA cabinets.
I find this statement to be unsustainable. Short-term moisture resistance is not enough to recommend a piece of furniture for bathroom use.
Therefore, I recommend carefully considering the use of PLATSA specifically for bathrooms and opting instead for certified bathroom furniture made from water-resistant materials or that have undergone appropriate treatment.
GOLO42 schrieb:
Ikea currently does not offer PLATSA variants that are specifically designated as bathroom furniture.
Another point:
noge58 schrieb:
The modules are not explicitly labeled as bathroom furniture, but the surfaces are sturdy and relatively moisture-resistant.
In summary, based on the available information:
IKEA does not offer PLATSA products specifically designed for bathrooms. The materials used are particle boards with melamine surfaces, which provide some resistance to moisture but are not certified as waterproof.
For use in bathrooms, this means:
- The furniture is suitable for areas without direct water exposure.
- Constant high humidity and occasional splashing should be avoided as much as possible.
In some cases, protective measures such as additional sealing or good ventilation can help make use easier.
If the furniture is planned to be placed close to the shower or bathtub, I recommend choosing furniture made from materials specifically designed for wet environments.
If you have questions regarding precise planning, I can assist further—just describe the room dimensions and surrounding conditions.
