ᐅ Are there any tips for reinforcing Malm drawers?
Created on: 1 Oct 2020 08:37
drabo
drabo
1 Oct 2020 08:37
I have been using the Ikea Malm chest of drawers for several years, and recently I've noticed that the drawers feel quite unstable, especially when fully loaded. There are often creaking noises, and I get the impression that the materials and joints are not as sturdy as they were at the beginning.
Are there any proven tips or methods to reinforce the stability and load-bearing capacity of the Malm drawers? Possible options might include strengthening the drawer boxes, upgrading the drawer slides, or adding additional supports. I’m not looking to simply buy new drawers but rather want to see how I can safely and durably use the ones I already have.
I look forward to specific suggestions, perhaps including recommendations for suitable materials or tools. Thanks!
leguson
1 Oct 2020 09:05
I would recommend replacing the plastic drawer bottom supports with sturdy metal reinforcements. Additionally, you can add extra screws at the joints to increase stability.
RENMA
1 Oct 2020 10:32
An effective method to reinforce Malm drawers is to increase the load capacity of the drawer bottoms. This can be achieved by attaching aluminum angle profiles to the underside of the drawer bottoms, which help distribute the weight more evenly.
Additionally, the drawer slides should be inspected regularly and, if necessary, replaced with higher-quality, enclosed runners to provide greater stability and smooth, jerk-free operation.
Furthermore, all screw connections should be checked, as Ikea furniture can lose stability over time due to slight movements. It is recommended to use thread-locking compounds or glue to secure the connections.
LAURE-TA
1 Oct 2020 13:47
Hello drabo,
I’m happy to give you a simple step-by-step guide on how to reinforce your Malm drawers:
1. Check the drawer bottom: Often the bottom panel is made of thin MDF, which can warp or break over time. You can add extra reinforcement here, for example, a thin plywood sheet (about 6-8 mm (0.24-0.31 inches)) that you attach underneath the original bottom panel with wood dowels and wood glue or screws.
2. Strengthen the carcass edges: The back panel and side edges of the drawer contribute significantly to stability. Use small metal brackets or wooden braces here to secure the corners.
3. Inspect the runners: The original plastic running elements often break. Metal runners with ball bearings are recommended. These can also be retrofitted if the dimensions fit.
4. Tighten screws: Tighten all screws and fittings to reduce any play.
5. Cleaning and lubrication: Clean the runners and apply light lubrication to ensure smooth operation.
If you want more detailed help with any step, just let me know!
Ernesto
2 Oct 2020 07:21
Good morning,
I would like to delve deeper into the topic from a technical perspective and share some details that are often overlooked:
The Malm drawers are generally made from relatively thin particleboard or MDF to keep costs low. This means the load limits are quickly reached when heavily filled. The load-bearing capacity can be significantly increased with the following measures:
- Reinforcement of the bottom supports: The original plastic inserts usually only support lightly loaded bottoms. A stable alternative is U-shaped metal profiles fixed to the underside. Make sure the dimensions fit exactly – too much play reduces the stabilization.
- Carcass construction: I recommend additionally gluing and screwing the side panels to the bottom. Excess material inside the joints can be repaired with wood filler to strengthen the structure.
- Drawer slides: Under load, the drawer runners experience lateral forces that can cause cracks or distortion if the installation is unstable. Upgrading to high-quality full-extension metal slides with ball bearings provides better support and smoother operation.
One more note: If you often store very heavy or sharp-edged items, consider using drawer inserts or dividers to evenly distribute the load.
Could you also add how the drawers are currently being used? That will help suggest targeted optimizations.
drabo
2 Oct 2020 09:44
Ernesto schrieb:
If you often store very heavy or bulky items, consider using drawer dividers or inserts to distribute the weight evenly.
Thanks for the tip, Ernesto. I often store books and electronic accessories in the lower drawers, so sometimes quite heavy and irregularly shaped items.
LAURE-TA schrieb:
You can add extra reinforcement here, for example a thin plywood sheet (about 6-8 mm (0.24–0.31 inches)) that you glue or screw underneath the original drawer bottom using wooden dowels and wood glue.
That sounds very interesting. However, I wonder if the drawer slides will still work smoothly if the drawer bottom becomes thicker due to the added panel.
Also, I wanted to ask whether it’s better to attach the reinforcement screwed or glued—especially regarding the drawer’s functionality.
Looking forward to opinions on this point.
