ᐅ Are there any tips for protecting Ikea Hemnes furniture from moisture?
Created on: 8 Feb 2016 08:37
Peerlen
Peerlen
8 Feb 2016 08:37
I recently purchased an Ikea Hemnes piece of furniture (a cabinet) and am now considering the best way to protect it from moisture. Since Hemnes is made of solid pine wood, I am wondering which specific measures are advisable if the cabinet is placed in areas with higher humidity levels, such as a bedroom with a window exposed to moisture or a utility room.
What tips or experiences can you share? I am also interested in advice regarding surface treatments, possible sealants, or preventative measures to prevent the wood from swelling or discoloring due to moisture exposure.
Thanks in advance for any helpful suggestions!
Annedeo
8 Feb 2016 09:03
Hello Peerlen,
First of all, it’s a good and sensible approach to consider moisture protection early on. Hemnes furniture is indeed made from solid pine wood, which is relatively durable but tends to swell and warp when exposed to moisture.
I recommend the following points:
- Try not to place the cabinet directly against exterior walls or areas with high humidity, such as bathrooms or kitchens.
- Ensure adequate air circulation around the furniture to prevent moisture buildup.
- An additional surface treatment, for example with wood oil or clear varnish, can reduce moisture absorption. If using oils, make sure to choose natural products that remain breathable.
- Avoid direct contact with wet objects or water.
- If possible, use a moisture absorber in the room, especially in more humid spaces.
I hope this helps you already! If you have any questions about using specific products, feel free to ask.
Christia59
8 Feb 2016 10:17
Exactly! I treated my Hemnes wardrobe with linseed oil back then and am very satisfied. 😊 The wood looks much nicer this way, and it really helps to keep moisture out. Important: Apply several thin layers and allow each to dry thoroughly in between!
Additionally, I highly recommend ventilating the area regularly. This is often essential to prevent mold or moisture damage. Good luck!
Klakar
8 Feb 2016 11:02
In short: Do not place the furniture in damp corners and treat the surfaces with wood varnish or oil. Don’t forget to ventilate.
Parbo
9 Feb 2016 07:45
Hello Peerlen,
to provide more targeted help, it would be useful to know in which room the Hemnes is located and how much the humidity levels fluctuate there. The appropriate protective measures depend greatly on whether you have consistently high humidity (e.g., utility room with a dryer) or occasional moisture exposure (bedroom with occasional ventilation).
Regarding surface treatments:
- Clear polyurethane varnish seals the surface very thoroughly, but this somewhat affects the natural wood appearance and reduces breathability.
- Oils, such as linseed oil, provide less sealing but allow the wood to breathe and absorb moisture more slowly.
- Wax can also be applied as an additional protective layer.
Application tips:
- The surface should be clean and free of dust before treatment.
- Apply several thin coats, allowing each to dry thoroughly.
About the furniture itself:
- Keep in mind that the back panels are often made of thinner material sheets, which are especially sensitive to moisture.
- You can protect them, for example, by applying a backing foil or leaving ventilation space behind.
In general, I can recommend the following detailed measures:
- Keep a gap of at least 2–3 cm (1–1¼ inches) from the wall to allow air circulation.
- Use a humidity controller in the room to monitor moisture levels.
- Regularly check the furniture for discoloration or deformation.
Do you have specific problem areas? Where exactly do you see a possible risk?
Peerlen
9 Feb 2016 08:16
Parbo schrieb:
To provide more targeted help, it would be useful to know which room the Hemnes is in and how much the humidity levels fluctuate there.
Thanks, Parbo! The wardrobe is in my bedroom, which does not directly border an exterior wall, but I have a window that often fogs up in the morning—so there is generally some humidity in the room. It’s not a damp basement or anything like that, more of a normal living environment with humidity usually around 50-60%, probably a bit higher in winter due to heating and ventilation habits.
I wanted to know if this level of humidity could be problematic for the pine wood and whether, for example, a clear varnish would be worthwhile or if oils are better to maintain the natural appearance. Which surface treatment is more suitable for use in a bedroom? Thanks!
