ᐅ Are there any tips for easily assembling Malm furniture?
Created on: 1 Aug 2020 09:13
Kikin
Kikin
1 Aug 2020 09:13
Hello everyone, I’m planning to get some Malm furniture pieces from IKEA and wanted to ask if anyone here has specific tips or tricks for assembling them quickly and easily? Since Malm items often consist of several components and the instructions can sometimes be quite confusing, I would like to hear about any experiences or methods that make the assembly easier overall – for example, special tools, steps to follow, ways to organize the parts, or helpful tricks to avoid mistakes or unnecessary stress. Thanks in advance!
V
vincent46
1 Aug 2020 10:47
I can completely understand how frustrating it can be when the instructions are not clear enough. From my experience with Malm, I recommend unpacking and sorting all parts completely at the start. For me, this was always less stressful than searching for screws while assembling.
Kikin schrieb:
würde ich gerne Erfahrungen hören, welche Vorgehensweisen den Aufbau insgesamt erleichtern
I have also found it helpful to work on a sufficiently large, clean, and level surface to ensure nothing gets lost. Patience is important, too—I often took my time and avoided rushing. Taking breaks when you feel frustration building up can also make a difference.
BEMAU
2 Aug 2020 07:38
For the systematic assembly of Malm furniture, I recommend the following approach:
First, sort all screws and fasteners into a small container to avoid missing parts during assembly. It is also important to prepare the necessary tools—usually hex keys (Allen wrenches) and Phillips screwdrivers are required.
vincent46 schrieb:
first unpack and sort all parts completely
is definitely a good idea to minimize confusion and errors.
Furthermore, I advise studying the instructions carefully step by step and following the sequence exactly, especially for components that will not be accessible later.
Tip: Do not tighten screws fully before all parts are assembled—this makes adjustments easier.
sanjon
2 Aug 2020 12:06
Brief and to the point:
1. Sort the parts.
2. Read the instructions carefully.
3. Position screws before tightening.
4. Use a large, clean workspace.
5. Be patient.
This has always helped me.
V
vincent46
3 Aug 2020 15:29
BEMAU schrieb:
Do not fully tighten screws before all parts are assembled
This is really great advice that I can only confirm. I have also tightened screws too early and then had to loosen everything a little again.
An additional tip: If you assemble the furniture with two people, it can make many things easier, especially when fitting bulky parts together. Some fittings are quite tight, so having a second person is really valuable. 🙂
