Hello everyone, I am facing the challenge of assembling an Ikea Pax wardrobe entirely on my own. Since the piece of furniture is quite large and has many individual parts, I’m wondering if anyone has tips or tricks that make the assembly easier without additional help? I am interested in practical tools as well as strategic approaches to manage tasks like connecting the carcass components or hanging the doors as effectively as possible alone. Are there any special techniques for organizing the space or parts, assembly sequence, or experiences with types of connections that I should know about? Thank you very much for any help!
Straps and screw clamps are very helpful when you don’t have someone to hold parts for you. Additionally, you should definitely:
- Use a cordless drill with a torque limiter.
- Sort all parts before assembly.
- Insert the back panel only after the main frame is assembled.
That’s all you need; everything else is optional.
poted schrieb:
For hanging the doors, a small stool or table is useful to raise the doors to the correct height and make installation easier.The issue with the doors is really my biggest problem. How can I practically solve this if I don’t have a second person? Do you have experience with temporary solutions I could use as a support device? For example, something I can safely rest the door on without it slipping or getting scratched?
Also: How about the attachment at the hinges? Is there a trick to fix them in place during installation?
Hello SIGAU, I can explain this well since I have assembled several Pax units on my own. For installing the doors, I recommend a simple setup:
- Lay down some old blankets or towels on the floor to prevent the doors from getting scratched.
- Use a sturdy side table or stool that is roughly at door height.
- Place the door on the soft surface and lean it against the side table positioned against the wall. This keeps the door stable.
- Use small wedges or wooden blocks under the door to prevent it from slipping.
- For the hinges, there are often small clips or spring mechanisms that you can use while hanging the door to help hold it temporarily in place.
Another tip: work with a screwdriver that has a magnetic tip. This way, you can hold the screws more easily without them falling and getting lost.
In summary:
- Soft surface to avoid scratches
- Side table at the right height
- Wedges to prevent slipping
- Magnetic screwdriver
This makes installing the doors almost as easy as doing it with two people.
In summary:
kuben schrieb:
As an additional tip: use a screwdriver with a magnetic tip. This way, you can position the screws more easily without dropping and losing them.Thanks, that’s a great addition. I actually have magnetic bits, but I didn’t realize how helpful they are during assembly.
One more question for clarification: At which point in the sequence is it best to install the back panel? Should it be done right at the start along with the side panels, or only once the frame is already stable? And how can I prevent the back panel from pressing on edges or screws before the structure is fully set?
SIGAU schrieb:
When exactly in the sequence is it best to install the back panel?The best recommendation is to install the back panel once the side walls and the floor are properly assembled, so that the frame has already gained some stability. The back panel provides the final rigidity. Make sure the back panel sits flush and is not installed with any bends. Before nailing it in place, check that all screws and dowels are flush so nothing pushes the back panel out or creates tension that could cause warping. If you are uncertain, you can temporarily fix the back panel with just a few nails before fully securing it.
Demetrius12 Sep 2018 10:02I understand that assembling such a large piece of furniture alone can be challenging. Especially the frustration when things don’t go smoothly can be stressful. My advice is: try not to put too much pressure on yourself and view the process as a challenge to be tackled step by step. It’s good to take breaks and avoid overexerting yourself. If you get stuck at any point, just take a short breather and then continue with renewed energy.
And importantly: celebrate the small achievements, for example when one side is finished or the back panel is in place. That really boosts motivation! You are on the right track.
