ᐅ Are there any DIY tips for redesigning IKEA Hemnes furniture?
Created on: 25 Apr 2023 09:37
anesno
anesno
25 Apr 2023 09:37
I own several IKEA Hemnes furniture pieces that I actually like in terms of design, but unfortunately, they look a bit outdated. I’m considering whether it’s possible to refresh and modernize the Hemnes series with simple DIY methods without completely replacing them.
Has anyone had experience with practices like sanding and repainting, replacing the handles, or other upcycling ideas that really work well? I’m especially interested in how to best treat the wood to achieve a durable and high-quality finish. It would also be helpful to know which materials and tools are really worth using and if there are common mistakes to avoid.
Are there any proven DIY tips for redesigning IKEA Hemnes furniture to give it a modern or personalized look?
Thanks in advance for your advice!
draleo
25 Apr 2023 13:46
When redesigning IKEA Hemnes furniture, a well-structured approach is recommended:
- Sanding: Hemnes is made from solid pine, so thorough sanding is beneficial to remove old paint layers and create a smooth surface. Use sandpaper with a grit of 120 to 220.
- Priming: To establish a stable base for the new paint, a wood primer is advisable, which also improves adhesion.
- Painting: A water-based acrylic paint is recommended, as it dries with low odor and provides a durable finish. Two to three thin coats are ideal.
- Replacing handles: Modernizing the handles is a particularly effective step, as Hemnes handles are distinctive. Minimalist metal handles or leather handles bring a new aesthetic.
- Alternative surface treatment: Staining instead of painting can also be an option if you want to preserve the wood character, although this requires more experience.
Common mistakes:
- Insufficient sanding and dust removal lead to uneven surfaces.
- Paint layers that are too thick cause cracks and unsightly drips.
- Cheap paints may lack durability, especially on high-traffic surfaces.
Tools such as a sanding block, brush or foam roller, and fine sandpaper are sufficient. I recommend a well-ventilated environment and enough drying time, preferably at a stable temperature.
If you have any specific questions about the paint brand or application, I am happy to help.
Takutau
26 Apr 2023 08:03
Hello anesno,
I think your question makes a lot of sense, as IKEA Hemnes furniture, made from solid wood, is well suited for individual modifications. My experience with this type of furniture shows that proper preparation is half the work. Here are some tips that might help you:
- Before sanding: Remove all fittings/handles and thoroughly clean the furniture with a mild cleaner to remove grease and dust.
- Sanding: Start with coarser sandpaper (80 to 100 grit) to roughen or remove the old lacquer layer, then proceed with finer paper (180 to 220) for a smooth surface.
- Priming: Especially with Hemnes, a good sealing primer is recommended to ensure the new paint adheres well and to prevent discoloration from the wood.
- Painting: Apply thin coats and allow each layer to dry completely. This helps avoid runs and uneven areas.
- Handles: Replacing the original handles with metal or leather ones can give almost any piece a more modern or even industrial look. Open or colored wood also adds a more personalized touch.
You can also decorate doors or drawers with wallpaper or contact foil if you prefer a more experimental approach.
Be sure to avoid applying thick paint layers, as this can cause cracking, especially on pine wood.
If you like, I can also provide you with a list of recommended products for surface treatment.
pikin
27 Apr 2023 10:29
Here is an additional note regarding design options for the IKEA Hemnes:
This is a fundamental and very important step that should not be overlooked. Only with a clean surface will the new paint adhere permanently.
Furthermore, I recommend:
- Using chalk paint as an alternative to traditional painting. Depending on the condition of the surface, it often adheres without extensive priming and sanding. This saves time and creates a modern shabby-chic look.
- After painting, sealing the furniture with wax to achieve a matte and authentic finish.
One more tip: If you decide on new handles, pay attention to the hole spacing, as it can vary between some Hemnes models. Measuring before purchase avoids frustration.
Regarding surface treatment: If you want to use stain, always apply a good primer first; otherwise, the pine wood may bleed through and discolor the paint.
These methods have proven effective for me and come from many years of experience in furniture restoration.
