ᐅ While moving, a corner of my KALLAX unit broke off – is a DIY repair advisable?
Created on: 17 Apr 2018 08:37
Ribedeo
Ribedeo
17 Apr 2018 08:37
During my last move, a corner piece broke off an IKEA KALLAX shelf. The damage is on the edge of one of the lower compartments, and it now looks a bit unsightly. I’m unsure about the best way to handle this.
My question to you is: Is a DIY repair for this kind of damage on a KALLAX shelf practical and durable, or would it be better to consider replacement parts or possibly a new shelf unit?
I have thought about using some wood glue and filler, then sanding and painting afterwards – but will this actually hold up in the long term? Are there any special tips or materials better suited for this kind of repair than ordinary household products?
Thanks in advance for your opinions and advice!
Muso4
17 Apr 2018 11:23
Ribedeo schrieb:
Is a DIY repair for damage like this on a KALLAX practical and reliably durable, or should I rather consider replacement parts or maybe a new shelving unit?
The fundamental question here is what “reliably durable” actually means in the context of IKEA furniture. Honestly, are these cardboard-based pieces ever truly stable enough to justify fixing such “wounds” with endless glue and filler?
I tend to favor more radical solutions. If there is a visible dent or scratch, you can repair it, but whether it will hold up is questionable. It’s usually better to buy new—it’s quicker, cheaper, and in the end looks better. But of course, for those who enjoy tinkering, DIY can be a practical option.
parbau
17 Apr 2018 12:46
Muso4 schrieb:
Honestly, are those cardboard furniture pieces ever really sturdy enough to make it worthwhile to fix those “damages” with endless glue and filler?
Well, I wouldn’t be that harsh! Of course, KALLAX isn’t solid wood, but repairing a small corner can definitely make sense if you approach it with a bit of patience. 😏
I once used a mix of wood filler and white acrylic paint – it almost looked like new and wasn’t expensive. If you do it with care, it holds surprisingly well! Wood glue also helps, especially if the broken parts still fit together somewhat. 🙂
Don’t apply filler too thickly, as that can cause unattractive cracks. In the end, lightly sanding with very fine sandpaper makes the repair almost invisible.
V
vinli
17 Apr 2018 16:08
To answer the question precisely:
KALLAX mainly consists of particleboard with a melamine coating, not a load-bearing solid wood construction. The corner area is mechanically stressed, where cracks can widen further under load if the repair is not done properly.
For a long-lasting repair, the following is recommended:
- Clean and remove any loose parts
- Use wood glue or assembly adhesive for proper bonding and hold
- Fill the gap with a special MDF wood filler putty
- Sand in multiple stages with fine-grit sandpaper
- Seal with a suitable paint or clear coat that adheres to melamine (e.g., acrylic or acrylic lacquer)
Regular wood glues and fillers can work if applied carefully, but durability is always limited. Replacement parts from IKEA are hard to obtain; buying new furniture may be more economical if the damage is severe.
nixon0
18 Apr 2018 07:55
Apply wood glue to the broken surface and press it firmly together. Then fill the area with MDF filler and sand it after it dries. Finally, apply paint or varnish. It will hold if you work carefully.
tangi
18 Apr 2018 10:16
vinli schrieb:
The corner area is mechanically stressed, where cracks can expand further due to load
This is exactly what makes the difference. If it is only a superficial defect, repairing makes sense. However, if you notice that the shelf is still being stressed at the corner, I would recommend considering some reinforcement – for example, a small strip reinforcement on the inside or a metal bracket structure.
Wood glue alone is usually not enough when the shelf has to bear weight, especially with frequent shaking or movement, such as during a move.
If you repair the KALLAX corner, make sure the material dimensions are accurate and the surface remains visually accessible after the repair; otherwise, you’ll have stability, but the appearance will suffer.
