ᐅ Single-family house floor plan, 1 full story, utilities and natural lighting
Created on: 22 Jul 2024 08:21
klabauter8614
Hello, I would like to gather feedback on the floor plan in order to finalize the design. We don’t have sections or elevations yet, but all other drawings are attached (house shown schematically on the site plan). Thanks.
Plot size: 473m² (5,089 ft²)
Slope: no
Site coverage ratio: 0.4
Floor area ratio
Edge development
Number of parking spaces: maximum 2 without garage
Number of floors: 1 full floor
Roof type: gable roof
Architectural style
Orientation: Roof facing NNE - SSW
Maximum heights / limits: eave height 4.2m (13.8 ft), ridge height 9.5m (31.2 ft)
Further requirements: only renewable energy sources, infiltration trench for stormwater
Basement, floors: no basement (groundwater level at 1m (3.3 ft) depth), 1 full floor
Number of occupants, ages: 4, aged 40-40-7-2 years
Space needs on ground floor and upper floor: Guesst room on the ground floor, office upstairs
Office use: family use or home office? Home office
Number of guest stays per year: 2 nights per week by one parent (also for coming years), parents-in-law stay several weeks annually
Open or closed layout
Traditional or modern construction
Open kitchen, kitchen island: semi-open (sliding door), kitchen island
Number of fixed dining seats: 6 fixed, expandable
Fireplace: no
Music/speaker wall: no
Garage, carport: garage
Utility garden, greenhouse: herb garden
Additional wishes/special points/daily routine, including reasons for preferences or exclusions
Planner: synergy between architect and client, now 4th draft
What do you particularly like? Why? Guest room and WC + shower, similar existing layout already working (although a bed is drawn, it is actually a sofa bed), office on the north side, guest room size more than sufficient, wardrobe by the entrance, living room bright, washing machine + dryer upstairs.
What don’t you like? Why?
- Utility room is half unusable due to wardrobe protrusion (which is actually sensible) so it is too small. Attic storage needs to be moved from the garage into the thermal envelope inside the utility room, indoor unit could stay there. The mechanical ventilation system would also need to be installed in the utility room. Possible solution: enlarge kitchen to the rear and expand utility room accordingly. This would make the house larger though. No other solutions discussed yet.
- Stairs are too steep; architect now proposes a rise/run of 17.2cm/26cm (6.8"/10.2"), which may be borderline regarding comfortable step depth.
- Daylight in children’s rooms might be low due to west-facing windows and roughly 12.5% window-to-floor area ratio; simulation might be needed. Skylights wouldn’t significantly improve this; only a dormer and smaller gable windows would.
- As drawn, the kitchen island layout is not suitable for me; passage from utility room too narrow, should be moved to the opposite side, with sink and window to the left.
- Air conditioning would still be needed in the bedroom and children’s rooms, but with the current window and furniture arrangement this looks impractical.
- Shower upstairs located under sloped ceiling, not necessary but a minor point.
- Skylight in guest WC is not at head height, should be slightly higher, also a minor detail.
- Bathroom door upstairs should open outwards.
- Storage under the stairs is still missing.
- Partition wall in garage is unnecessary.
Cost estimate from architect/planner: unknown
Personal price limit for house including fixtures: 650,000
Preferred heating technology: air-source heat pump
If you must give up something, which features or extensions
- Can you give up: walk-in closet
- Cannot give up: office, guest room
Why is the design like it is now?
Own design developed based on space requirements plus architect’s counter proposal
What do you consider especially good or problematic?
Main issues to resolve are utility room + technical space and daylight.
Floor plan ground floor with kitchen, living/dining, garage, terrace and garden.
Floor plan upper floor: bedroom, bathroom, hallway, dressing room, child 1, child 2, office.
Two house views: northwest with gable roof; northeast with garage and modern facade.
Two house views: southeast and southwest with garden, trees and windows.
Attic: storage 26.92 m² (289 sq ft), stairs, two roof windows, continuous roof edge.
Detailed plan of street layout with red roadway, sidewalks, parking spaces and green areas.
klabauter8614
2 Sep 2024 12:29
klabauter8614 schrieb:
I still don’t understand the third window—do you mean an additional window next to the door? What does that have to do with the canopy?
Here is the front view.
You did mention that several times, though I wonder if someone just copied it without considering the relative shift of the walls to the front door or if there is a reason behind it. Looking at the entrance, I tend to think it’s the first option. The question remains, is this staircase in the optimal position for this floor plan? Besides the technical aspects, I think that also needs to be discussed. I just hope that the staircase isn’t simply replaced while everything else stays as is and then suffers as a result (which would basically bring us back to option #1).
@ypg Did you want to add any comments about the view?
@11ant For the children’s rooms with the high ceiling space, shouldn’t the windows be enlarged accordingly or should there be an extra window or skylight for the upper floor rooms? See the NW elevation. Of course, this can also be solved with artificial lighting.
Four house facades of a brick house: northwest, northeast, southeast, southwest[/ ALT]
hanghaus2023
2 Sep 2024 12:59
The view from the northeast will look like this.
Two-story house with metal roof, garage, entrance, two windows, garden, and two people in front
The window next to the door is 40cm (16 inches) wider.
From the southwest, it will look like this.
Architectural drawing of a modern brick house with flat roofs, windows, and trees.
klabauter8614
2 Sep 2024 13:30
If you want the entire axis to be exactly the same all the way to the back, sure. Although the kitchen door, shifted to the left anyway, wouldn’t interfere with the chairs. The fact that the door no longer aligns exactly with the window above is probably the consequence.
However, it looks quite extreme in your drawing: one door leaf is 1 meter (3 feet 3 inches) wide, and the front door is only shifted about 40 cm (16 inches) to the left, but here at the back the door is shifted by more than 1 meter (3 feet 3 inches).
11ant2 Sep 2024 13:34
@11ant For the KZ with the high ceiling, wouldn’t the windows also need to "grow" or should there be an additional window at the top for the upper floor in the rooms?
Children’s rooms, please, we do not want to evoke a repeated Shoah even after yesterday’s election results. You are probably referring to my suggestion of open-plan children’s rooms with a play/sleep treehouse level. Who wants to clean windows there?
hanghaus2023 schrieb:
The view to the northeast will look like this.
With a front door sized 34/36?
hanghaus2023
2 Sep 2024 13:48
With a front door size of 34/36?
The front door is 1 m (3.3 feet) wide. That should be sufficient.
hanghaus2023
2 Sep 2024 13:53
here on the back side the door is more than 1 meter (3.3 feet).
I measured a maximum of 1 meter (3.3 feet) at least. In the view, I focused more on the bricks, so it ended up a bit over 1 meter (3.3 feet). The architect will probably say that’s a no-go.
It’s just a visualization of the proposal by @ypg. Whether you want to have a clear view from the entrance all the way to the garden is a matter of personal taste.
