ᐅ Suppliers of wood-aluminum windows for new construction
Created on: 31 Mar 2023 19:13
mike_rose
mike_rose
31 Mar 2023 19:13
we are currently in the middle of planning our new home and are focusing on the topic of windows. Our favorite option is wood-aluminum windows. We have heard from acquaintances that it is sometimes possible to purchase these directly from the manufacturer at a somewhat lower price—sometimes even in Poland. Are there any tips or experiences regarding this?
Looking forward to your advice and opinions.
Allthewayup
31 Mar 2023 19:20
I don’t have experience with windows from Poland, but at the moment I can’t say anything good about Rehau windows. There are many inclusions between the panes and compressed seals. You can find poor-quality windows anywhere. For a new build, I would only get windows from a specialist. With timber-aluminum windows, you’re entering the premium price range right away. We chose composite windows with PVC-aluminum as the best value for the price.
Bausparfuchs
31 Mar 2023 19:35
What is the reason for choosing wood-aluminum windows?
There are basically only two reasons: either you have a lot of money, or you want to bring trouble with the windows into your home.
A wooden window always requires maintenance. Wood is a living material. It absorbs moisture and releases it again. It swells and shrinks. To make a wooden window more weather-resistant, it is clad with aluminum on the outside. However, moisture can still accumulate on the inside, potentially damaging the window. After about 10 years, if you are unlucky, it may need sanding and repainting.
Vinyl (uPVC) windows or aluminum windows are significantly more durable and require less maintenance.
11ant31 Mar 2023 20:05
mike_rose schrieb:
We are currently deep in the planning stage of our new home and are focusing on the topic of “windows.” Our favorite choice so far is “wood-aluminum windows.”
I have basically said everything about this topic, or you can find all my thoughts here: https://www.hausbau-forum.de/threads/holz-alu-fenster-worauf-achten.38145/#post-472834
mike_rose schrieb:
We have heard from acquaintances that you can sometimes purchase these directly from the manufacturer at a slightly lower price – sometimes even in Poland. Are there any tips or experiences regarding this?
If you want my experience as a former window manufacturer (aluminum) and dealer (all materials): I don’t know a single window manufacturer that is any good AND sells factory outlet directly to end customers – it’s always one OR the other.
mike_rose
1 Apr 2023 14:22
I have actually said everything about this, or you can find all my comments here: https://www.hausbau-forum.de/threads/holz-alu-fenster-worauf-achten.38145/#post-472834
If you want my experience as a former window manufacturer (aluminum) and dealer (all materials): I don’t know a single window manufacturer that is reliable AND runs a factory outlet sale directly to end customers – it’s always one OR the other.
Hello 11ant! Thank you very much for your expertise! We will review your older posts on this topic and reconsider the "wood-aluminum windows"! Initially, we felt good about wooden windows in terms of indoor air quality and health. But maybe the other materials are also safe. Best regards
11ant1 Apr 2023 14:44
mike_rose schrieb:
Hello 11ant! Thank you very much for your expertise! We are reviewing your older posts on this topic and reassessing the “wood-aluminum windows”!
Also check out my external window posts (searching for "How many chambers does a window need" including the quotation marks should lead you to this series), and always keep in mind: wood/aluminum is either more expensive than pure aluminum or unfortunately BSD.
mike_rose schrieb:
At first, we felt good about wood windows regarding indoor climate and health. But perhaps the other materials are also safe.
The naive “organic” label feeling is a major reason for the (often wrong) decision in favor of wood/aluminum. Knowing your house design, I could give a more precise window recommendation; usually, I combine PVC with aluminum (for the front door and other exposed elements). Wood or wood/aluminum is practically only considered economically viable for privately insured owners and, compared to pure aluminum, is only different, not better.
