bodacious16 Dec 2022 13:52Hello!
Here in East Frisia, I have received an initial offer from a local heating and bathroom company. It involves a complete demolition and reconstruction of a bathroom from the 1990s. All fixtures will remain in their original positions. The company manages the project from start to finish.
I find the many details reassuring. At first, the price was surprising, but perhaps it can be reduced by choosing more affordable materials. Next week, we will visit the company to discuss the specifics, such as sanitaryware, bathroom furniture, tiles, etc.
I am considering getting a quote from another company for comparison. What do you think about this offer?
Washbasin set 650mm (26 inches), consisting of:
- Washbasin Villeroy & Boch Architectura 65x47cm (26x18.5 inches) white
- Crystal mirror 80x60cm (31.5x24 inches) rectangular
- Single-lever washbasin mixer Eurostyle Grohe
- Double-arm towel holder Loft
€574
Wall-mounted toilet set, consisting of:
- Wall-hung rimless toilet white Villeroy & Boch Architectura
- White toilet seat with soft-close
- Concealed cistern Geberit
- Geberit flush plate white
- Soundproofing kit
- Chrome-plated Loft toilet paper holder
€1,008
Shower tray set consisting of:
- Kaldewei steel shower tray 90x90x2.5cm (35x35x1 inch)
- Mounting frame for shower tray
- Sealing tape for shower tray
- Tempoplex drain unit 90mm (3.5 inches)
- Tempoplex chrome cover cap
- Strainer for Tempoplex/Plus drain fitting
- Surface-mounted thermostatic valve Grohe
- Shower set 90cm (35 inches) Grohe
€993
Shower enclosure consisting of:
- Favorit Nova corner entry, 4-piece up to 90x90cm (35x35 inches), clear toughened glass, aluminum profile silver matte
€1,139
Bathtub set consisting of:
- Kaldewei steel Saniform bathtub 180x80cm (71x31.5 inches)
- Universal support frame
- Bathtub trim strips Mepa
- Bathtub sealing tape 3.0m (10 feet)
- Drain/overflow fitting Multiplex DN 40/50
- Color set for Multiplex Visign M5
- Single-lever mixer Eurostyle Grohe
- Hand shower, holder, and hose
€1,237
Radiator consisting of:
- Bathroom radiator Line white 600x1775mm (24x70 inches) including fittings
- Heimeier Multilux valve set
- Compression fittings
€513
Wall and floor tiling work up to 12.5m² (135 sq ft), including the following materials:
- Wall tiles 30x60cm (12x24 inches)
- Floor tiles 30x60cm (12x24 inches)
- Tile adhesive
- Grout slurry
- Primer
- Permanently elastic silicone joints
- Edge trims
- Stones, mortar, etc.
- Construction boards
€8,181
Screed including insulation and small materials up to 12.5m² (135 sq ft)
€448.00
Piping and accessories
Bathroom demolition up to 12.5m² (135 sq ft) including debris removal
€1,295
Supply and installation of sewage, water, and heating pipes including insulation, fastening materials, etc. up to 12.5m² (135 sq ft)
€1,385
Underfloor heating up to 12.5m² (135 sq ft) including concealed box Danfoss
€549.96
Ceiling work up to 12.5m² (135 sq ft)
- Plasterboard
- Substructure
- Fastening materials
- Drilling for recessed spotlights
€889.00
Ceiling panel work up to 12.5m² (135 sq ft)
- Moisture-resistant panels
- Finishing profile
- Substructure
- Drilling for recessed spotlight €1,129.00 each
- Interior door including frame up to 100cm (39 inches)
- Stainless steel WC flush actuator set
€599
Bathroom fixtures €4,326.43
Tiles €8,629.69
Piping and accessories €3,229.96
Other work €1,488.00
Net total €17,674.08
19.00% VAT €3,358.08
Total amount €21,032.16
Tiling seems a bit expensive to me (but it could also be the market situation). The rest are typical contractor prices. So, not super cheap but also not really expensive.
For the shower, it would also depend on the specific set, as prices range from 250 to 2000 EUR (approximately 270 to 2150 USD).
bodacious16 Dec 2022 14:03Tolentino schrieb:
The tiles seem a bit expensive to me (but it could also be the current market situation). The rest is normal tradesman pricing—so not super cheap, but not really expensive either. In many places, it says "up to 12.5m² (135 sq ft)." I’m not sure if this refers to the maximum prices for a bathroom that size, and since our bathroom is smaller, the final quote should be lower. That’s something we need to ask about.
bodacious16 Dec 2022 14:08Tolentino schrieb:
Usually, the tiling area is specified. That means both floor and wall surfaces! This is very important! You don’t want to misunderstand each other. Yes, I hope the price will be reduced once the exact tile requirements are discussed.
About a year ago, we also had our bathroom renovated. It was somewhat smaller (6 sqm (65 sq ft)), but included a new ceiling with recessed lighting and underfloor heating. In our case, the vanity was significantly larger, and the other fixtures were a bit more expensive, for example, a shower tray with non-slip surface, a large mirrored cabinet, a shower system with overhead showerhead, and the bathtub was also a very high-end model. Our quote was around 27,000 EUR.
The work was carried out this year, but we are still waiting for the final invoice. Therefore, I can’t say exactly yet whether we stayed within budget. However, many items in our quote were based on time estimates and billed according to actual hours worked. These estimates turned out to be quite accurate overall.
Thanks to working from home, I was able to closely track who did what, when, and how long it took.
If you have the time, definitely get a second quote. We didn’t because we know the plumbing company and some of the staff personally, so we felt fairly confident that they would do a good job—which they ultimately did. We also knew that we had chosen some rather expensive fixtures, so the price didn’t come as a complete surprise.
