Hello!
Here in East Frisia, I have received an initial offer from a local heating and bathroom company. It involves a complete demolition and reconstruction of a bathroom from the 1990s. All fixtures will remain in their original positions. The company manages the project from start to finish.
I find the many details reassuring. At first, the price was surprising, but perhaps it can be reduced by choosing more affordable materials. Next week, we will visit the company to discuss the specifics, such as sanitaryware, bathroom furniture, tiles, etc.
I am considering getting a quote from another company for comparison. What do you think about this offer?
Washbasin set 650mm (26 inches), consisting of:
- Washbasin Villeroy & Boch Architectura 65x47cm (26x18.5 inches) white
- Crystal mirror 80x60cm (31.5x24 inches) rectangular
- Single-lever washbasin mixer Eurostyle Grohe
- Double-arm towel holder Loft
€574
Wall-mounted toilet set, consisting of:
- Wall-hung rimless toilet white Villeroy & Boch Architectura
- White toilet seat with soft-close
- Concealed cistern Geberit
- Geberit flush plate white
- Soundproofing kit
- Chrome-plated Loft toilet paper holder
€1,008
Shower tray set consisting of:
- Kaldewei steel shower tray 90x90x2.5cm (35x35x1 inch)
- Mounting frame for shower tray
- Sealing tape for shower tray
- Tempoplex drain unit 90mm (3.5 inches)
- Tempoplex chrome cover cap
- Strainer for Tempoplex/Plus drain fitting
- Surface-mounted thermostatic valve Grohe
- Shower set 90cm (35 inches) Grohe
€993
Shower enclosure consisting of:
- Favorit Nova corner entry, 4-piece up to 90x90cm (35x35 inches), clear toughened glass, aluminum profile silver matte
€1,139
Bathtub set consisting of:
- Kaldewei steel Saniform bathtub 180x80cm (71x31.5 inches)
- Universal support frame
- Bathtub trim strips Mepa
- Bathtub sealing tape 3.0m (10 feet)
- Drain/overflow fitting Multiplex DN 40/50
- Color set for Multiplex Visign M5
- Single-lever mixer Eurostyle Grohe
- Hand shower, holder, and hose
€1,237
Radiator consisting of:
- Bathroom radiator Line white 600x1775mm (24x70 inches) including fittings
- Heimeier Multilux valve set
- Compression fittings
€513
Wall and floor tiling work up to 12.5m² (135 sq ft), including the following materials:
- Wall tiles 30x60cm (12x24 inches)
- Floor tiles 30x60cm (12x24 inches)
- Tile adhesive
- Grout slurry
- Primer
- Permanently elastic silicone joints
- Edge trims
- Stones, mortar, etc.
- Construction boards
€8,181
Screed including insulation and small materials up to 12.5m² (135 sq ft)
€448.00
Piping and accessories
Bathroom demolition up to 12.5m² (135 sq ft) including debris removal
€1,295
Supply and installation of sewage, water, and heating pipes including insulation, fastening materials, etc. up to 12.5m² (135 sq ft)
€1,385
Underfloor heating up to 12.5m² (135 sq ft) including concealed box Danfoss
€549.96
Ceiling work up to 12.5m² (135 sq ft)
- Plasterboard
- Substructure
- Fastening materials
- Drilling for recessed spotlights
€889.00
Ceiling panel work up to 12.5m² (135 sq ft)
- Moisture-resistant panels
- Finishing profile
- Substructure
- Drilling for recessed spotlight €1,129.00 each
- Interior door including frame up to 100cm (39 inches)
- Stainless steel WC flush actuator set
€599
Bathroom fixtures €4,326.43
Tiles €8,629.69
Piping and accessories €3,229.96
Other work €1,488.00
Net total €17,674.08
19.00% VAT €3,358.08
Total amount €21,032.16
bodacious16 Dec 2022 15:28FloHB123 schrieb:
About a year ago, we also renovated our bathroom. It’s a bit smaller (6 sqm (65 sq ft)), but we had a new ceiling including recessed lighting and underfloor heating installed. Our washbasin was significantly larger, and we chose some more expensive fixtures, such as a shower tray with anti-slip surface, a large mirrored cabinet, a shower system with overhead showerhead, and the bathtub was also a very costly model. Our quote was 27,000 EUR.
The work was carried out this year, and we are still waiting for the final invoice. So I can’t say for sure yet if the costs matched the quote. However, many items in our quote were based on estimated effort and settled according to actual work done. These estimates were quite accurate overall.
Thanks to working from home, I was able to closely follow who did what and how long it took.
If you have the time, definitely get a second quote. We didn’t, because we know the plumbing company and some of the employees personally, so we were quite confident the job would be done well (which turned out to be true). We also knew we had selected some rather expensive items, so the price didn’t come as a big surprise to us.Interesting, thanks. Is the underfloor heating water-based or electric? How do you like it?
Did you make any advance payments?
The underfloor heating system uses water. We never paid anything in advance. However, shortly before completion, we received and paid an interim invoice for 15,000€ (about 15,000 euros). At that point, approximately 80% of the work was completed, so that was acceptable. We are still waiting for the final invoice.
O
OBM München19 Dec 2022 16:3412 m² (130 ft²) for around €21,000
This is an affordable price
Buschreiter19 Dec 2022 22:08We were in a similar bathroom, but without a bathtub, instead with a significantly larger washbasin, a bigger shower, and rectified tiles in a comparable area (Cologne). There were no advance payments, but two progress payments. Especially with tiles, the price per square meter for the tile installer is important; the tiles themselves do not make up a large part of the total cost. Getting a second or third quote is important, and having a plumber “around the corner” is extremely helpful in case any problems arise.
