ᐅ Pressure washer—but which one?
Created on: 15 Jan 2022 05:48
lin0r87
The time is slowly coming when it’s possible to clean the driveway and the terrace.
I’m already thinking about a pressure washer, but which one would be suitable?
It’s clear that Kärcher is the market leader and very good quality.
What alternatives do you have and would recommend?
rick201817 Jan 2022 16:53
But not for large surfaces 😉
Fortunately, we mainly use coverings that are suitable for high-pressure cleaning.
Our high-pressure cleaner also serves other purposes, such as for the pool, etc.
11ant17 Jan 2022 17:16
haydee schrieb:
Scrubbing is good for the muscles and metabolism, and if done quickly, it can replace cardio training.
Haha, like a high blood pressure cleaner 🙂
fünftesWort
Tarnari17 Jan 2022 17:53
In my first training company, we sold Kärcher and Kränzle. I was strongly advised to sell a Kränzle whenever possible. As mentioned above, Kränzle uses a lot of brass parts, while Kärcher products are mostly made of plastic. There were reportedly many complaints about broken plastic screw fittings on Kärcher machines, and replacement parts were not available for those. At that time, with Kränzle, everything could at least be replaced.
However, that was almost 25 years ago. Maybe things have changed since then.
Regarding floor coverings, I could imagine that manufacturers are often overly cautious, following a “warning! Risk of burns!” approach—for example, with coffee from McDonald’s.
What I actually find problematic are the joints. They can probably get “empty” or overly cleaned very quickly…
tomtom7917 Jan 2022 20:29
Attached a simple Gardena joint scraper to a handle and gave it a try.
It took me 2 hours to clean 70m2 (750 sq ft).
Using a pressure washer only created noise and dirt, and the joints ended up empty.
rick201817 Jan 2022 20:59
Rotating brushes can also be used for joints.
70m2 (750 sq ft) is not that much either.
tomtom7917 Jan 2022 21:16
rick2018 schrieb:
You can also use rotating brushes for the joints.
70m2 (750 sq ft) isn’t that much area.
I have this surface cleaner with rotating water jets, but as I said, it didn’t really work that well.
