ᐅ Pressure washer—but which one?
Created on: 15 Jan 2022 05:48
lin0r87
lin0r8715 Jan 2022 05:48
The time is slowly coming when it’s possible to clean the driveway and the terrace.
I’m already thinking about a pressure washer, but which one would be suitable?
It’s clear that Kärcher is the market leader and very good quality.
What alternatives do you have and would recommend?
HilfeHilfe
15 Jan 2022 06:48
Kärcher: if you buy cheap once, you get cheap quality.
guckuck2
15 Jan 2022 07:24
In the price range of 100-150€ (approximately $110-$165), I also ended up with Kärcher. However, these are quite plastic-heavy machines. I don’t think these devices are top-quality; it’s more of a German thing, the term “kärchern.” Mine also overheats sometimes, so you have to let it cool down for about half an hour before continuing. If you want to spend more, I would rather take a look at Nilfisk.
haydee
15 Jan 2022 07:50
Check with the manufacturer of the paving stones and terrace slabs. Many advise against using a pressure washer.
rick201815 Jan 2022 07:57
Kränzle is also highly recommended. With Kärcher, you usually have to look at higher-end models to get a pressure washer with high-quality and durable components.
As @haydee already mentioned, using a pressure washer is not suitable for all types of patio slabs.
AMNE3IA15 Jan 2022 08:11
I agree with @rick2018. You can't go wrong with Kränzle. I recently got a Kränzle tst 1152. The quality is top-notch, and it is more than sufficient for typical household use.
