The time is slowly coming when it’s possible to clean the driveway and the terrace.
I’m already thinking about a pressure washer, but which one would be suitable?
It’s clear that Kärcher is the market leader and very good quality.
What alternatives do you have and would recommend?
Benutzer200 schrieb:
Works great!
Otherwise, a cheap device from Lidl & Co. is usually sufficient. Yes, that's the trick: if they run cooler, even budget devices last longer ;-)
Our pavers strongly advised against using a high-pressure cleaner. They said it damages the surface of the concrete pavers, causing them to get dirty even faster.
But apart from baking soda/soap/yeast and scrubbing manually with a brush, are there any other options? Probably not?
Is the mechanical stress from scrubbing really gentler on the stones than a pressure washer? I can't quite imagine that.
