Created on: 11 Sep 2018 07:32
rick2018
Now a bit about me:
Greetings from Swabia
Modern villa with flat roofs, terraces, glass surfaces, green surroundings – several views.
rick201825 Jan 2021 20:50
It’s warm in the pool and the house 😉
Besides, traveling is currently not practical and only possible with many restrictions.
Even our vacation, which was already postponed by a year, will most likely not happen.
But I have plenty to keep me busy, and we are enjoying the house and what it offers.
Tarnari25 Jan 2021 21:28
@rick2018 could you please tell me how tall the cooking chamber is? It looks very shallow. Can I roast a whole chicken upright in there? From the picture, it doesn’t seem possible.
And I also believe that a Napoleon Prestige is anything but cheap. At least for me, no grill with cast iron grates will ever enter the house again. They are bound to be discarded.
rick201825 Jan 2021 22:13
@Tarnari I didn’t measure it, but it’s enough. Otherwise, you can also use a rotisserie.
The Napoleon Prestige is definitely not cheap, but it’s not comparable to the Flammkraft at all (unfortunately not in price either).
The Block D has roughly the same cooking surface as the largest Prestige model. On the far left is a beefer section. You can also insert a stainless steel plate there.
I like coated cast iron grates. They retain heat much better. Also, none of mine have broken so far. After cooling down, just spray some cooking oil on and wipe it off with a cloth, and that’s it.
My grill is also covered and kept under a roof.
Spending several thousand euros on a grill is only justifiable as a hobby. If you can’t cook a steak on a cheap grill, you won’t manage it on a €6,000 grill either. Combined with sous vide, it gets even easier.
I was looking for a grill with a larger cooking surface, good quality, and appearance.
The Flammkraft is definitely a different league compared to a Weber grill or Napoleon.
Tarnari25 Jan 2021 22:57
@rick2018 my post might have been a bit unclear.
Regarding your grill, I was basically only referring to the height of the cooking chamber.
The rest of the post was more directed at those who claim that everything else is “cheap.” You have to see everything in context. Comparing a $6,000 grill to a $2,000 grill only makes sense if you have that kind of money. Hobby or not. (As I said, this is not aimed at you). Such a comparison doesn’t do justice to either grill. It would be bad if your grill didn’t stand up well against a grill like that.
As for the grate, yes, cast iron retains heat much better. In my experience, if you tend to use a grill 4-5 times a week and cook on it regularly, these things unfortunately deteriorate quickly. Whether cared for or not. That’s just the nature of the material. Iron rusts, after all.
In the end, it might also be a matter of personal preference. Like with many things.
How it behaves with the grate on a $6,000 grill, I honestly can’t judge. It might be different there.
rick201826 Jan 2021 07:36
I can measure it sometime when I get the chance.
Schimi179126 Jan 2021 07:54
I can hardly wait for it to start again... 😀
Grill plate with sausages, chicken drumsticks; cucumbers in dip on the left, tomato-pepper vegetables on the right.
Grill on balcony: chicken on a rotisserie, sausages, mushrooms, and colorful vegetables on the grilling surface.
Or maybe a grill thread would be better? 😉
