ᐅ Floating solid hardwood flooring installation—any experiences?
Created on: 19 Sep 2020 12:14
pagoni2020
since we have screwed solid wood planks on joists in almost the entire house for many years and really liked it, we are now considering whether to choose solid wood planks again in the new house, but this time with underfloor heating and therefore directly on the screed.
We do not want an adhesive floor, so we are looking for experiences with floating solid wood plank installations.
Steffi33
20 Sep 2020 21:00
pagoni2020 schrieb:
this time with underfloor heating and therefore installed directly on the screed.
We have solid wood floorboards in the living areas. Since we didn’t want to glue them down, we ultimately decided against underfloor heating and chose radiators instead... The screed was omitted... Instead, joists were installed, onto which the floorboards were screwed. Regards.
Interior with wooden floor joist frame on concrete floor, radiator on the wall
Interior of a new build: stack of wood planks on substructure, grey walls and visible passage.
Interior under construction: wooden floor being installed; exposed floor joists, columns, radiator, circular saw.
Empty room with new wooden floor, green walls, radiator and windows.
Empty room with light blue walls, large window, radiator and light wooden floor.
F
fach1werk
20 Sep 2020 21:05
That looks really great!
pagoni2020
20 Sep 2020 21:12
Ah yes... that’s exactly how we had it in our old house, but we had a cork underlayment in between. Even after 30 years, we still have the same flooring with no issues and great comfort.
Congratulations!!!
Actually, that would have been my first choice for the new house as well, but most likely it will be underfloor heating, which would rule that out.
Many thanks for these lovely pictures... I do miss that wooden floor a bit.
nordanney
20 Sep 2020 21:40
pagoni2020 schrieb:
Actually, this would have been my first choice for the new house as well, but most likely it will be underfloor heating, so that option would be ruled out.
Just a tip. This is also possible with underfloor heating! There is a special system for that. You can have both. Just try searching online.
Tolentino20 Sep 2020 21:51
chand1986 schrieb:
Sorry for going off-topic, but there is a sound difference between speaker cables.
So does that mean there is also a difference in the feel of different flooring?
nordanney schrieb:
Maybe over 20m (65.6 ft) between 0.5mm² (20 AWG) aluminum and 4.0mm² (11 AWG) copper. Otherwise, people can measure differences but not hear them acoustically. The rest is caused by the dissonance of the high cable price...
We once tested this with acoustic engineers and a double-blind test. One out of five got over a 50% hit rate (5m (16.4 ft) 2.5mm² (14 AWG) copper stranded wire versus preassembled 6mm² (10 AWG) gold-plated reference gear), which reached 60%.
You think you hear differences, but when the supposedly worse cable sounds better half of the time, you stop believing these audiophile legends.
HarvSpec
20 Sep 2020 22:26
nordanney schrieb:
Just a tip. This also works with underfloor heating! There is a special system for that. You can have both. Try searching for it online.
We installed it!
Heating plates with underfloor heating running inside, with spacers in between where the floorboards are screwed down!
For example, Cosmo Top 30, but there are other manufacturers as well.
