ᐅ Installing oak parquet floorboards on underfloor heating using a clip system without adhesive
Created on: 28 Aug 2019 11:58
Gausek
Gausek28 Aug 2019 11:58
We have underfloor heating embedded in the screed and want to use solid oak planks 20mm (3/4 inch) thick as our flooring. We don’t want to use adhesive because of all the emissions, even though that would obviously provide the best bonding.
Has anyone had experience with these clip systems where the planks are installed floating? The clips are supposedly placed either under the planks or between the wall and the planks.
Of course, it’s clear that the heat transfer won’t be as good as with glued flooring. That doesn’t bother me; we’ll simply heat a bit more if it’s not warm enough. By the way, we have a gas boiler.
So the specific question is: Has anyone had good or bad experiences with clip installation? Or did anyone have the floor lift up because the fastening method perhaps didn’t hold?
Thank you very much.
KlaRa31 Aug 2019 16:36
Hello, questioner.
The system with spring clips between individual floorboards has been around for about 30 years, so it’s nothing new.
It was already used back then by the company JUNCKERS for high-quality solid wood planks and multi-layer parquet – and it worked excellently!
Regards: KlaRa
Bookstar
31 Aug 2019 22:50
There are organic adhesives available, so you don’t have to worry anymore.
Scout
1 Sep 2019 10:17
We have no issues at all with the system from Weiss. But without underfloor heating.
@Bookstar Ökotest and Warentest have tested parquet adhesives several times and could not give a final rating to any adhesives without toxic emissions.
Bookstar
1 Sep 2019 10:29
How do you then fix your tiles? Don’t you have any furniture or a kitchen? There’s certainly nothing toxic left there, more likely just potentially harmful. Controlled residential ventilation and regular airing help quite well with that.
I wouldn’t let it drive me crazy.
Mycraft1 Sep 2019 10:38
This is how it looks. Upholstered furniture or electrical appliances usually emit far more odors.
Turn on the ventilation!
