I need your expert advice.
I wanted to install an outdoor water meter for the garden and assumed—since I’ve had one before—that it would be fairly simple to use a screw-on meter at the external tap. However, after checking with the local utility company here, they do not allow such meters, even with a seal. The meter must instead be permanently integrated into the household plumbing system.
So far, so good.
What practical options are there if the indoor piping doesn’t accommodate this? The outdoor tap is located on the ground floor and there’s no separate supply line in the basement where a meter could be installed; otherwise, all other water consumption on the ground floor would also be included. The outdoor tap itself is a frost-proof valve from Kemper—could a meter perhaps be integrated there somehow?
Thanks in advance for your help!
So far, so good.
It varies from municipality to municipality.
Try calling again. Sometimes it depends on the staff member...
and ask them to send you the regulation where it is described.
With low consumption, the costs for an additional meter (calibration; fees, regular replacement, etc.) are usually not worthwhile.
HilfeHilfe5 Apr 2020 10:37We have a Gardena meter installed... Besides, what do you want to achieve with the meter? Just statistics? Then install one like that. No one has ever been in our garden.
