ᐅ What do internal muntins look like with triple glazing?
Created on: 19 Dec 2019 18:42
Pinkiponk
Have any of you installed windows and patio doors with muntins, and what do the internal muntins look like with triple glazing? Could I see some photos? From Google images, I can't tell whether the windows are triple- or double-glazed.
Pinkiponk
20 Dec 2019 09:28
pffreestyler schrieb:
We do. But honestly, I don’t even understand your question?! Where exactly should there be a visible difference between double and triple glazing?
As a layperson, I assume that with double glazing the spacers can be in the middle, but not with triple glazing.
Pinkiponk
20 Dec 2019 09:30
hampshire schrieb:
They look almost identical. You can easily see and experience this yourself in a specialist store.
Yes, please excuse me, I took it a bit easy since we live in a rural area with no nearby options to see these types of windows in person. I assume we will be able to see them during the selection process and wanted to hear opinions/experiences beforehand.
pffreestyler
20 Dec 2019 10:02
Even DIY stores often provide this.
I will upload a photo of our window with a muntin bar this evening.
Pinkiponk
20 Dec 2019 10:22
Even hardware stores often issue that.
I’ll upload a photo of our window with mullions this evening.
Thank you.
hampshire
20 Dec 2019 10:57
Pinkiponk schrieb:
because we live out in the countryside with no nearby options to see those kinds of windows in person.
I understand that – the distances are just a bit longer. Bretten isn’t exactly remote; there are several window manufacturers and building supply stores there. Call ahead, drive over, take a look. It takes some time but gives you a better feeling when making your decision. The visual differences between two models are usually more noticeable than the technical differences between double- or triple-glazing.
11ant20 Dec 2019 13:36
Pinkiponk schrieb:
As a layperson, I think that for double glazing they can sit in the middle, but not for triple glazing.
For the space between the panes, with triple glazing it would be the same as with double glazing, each time in the first cavity seen from the inside. However, I wouldn’t do that, because the glazing bars would have to be installed by the glass supplier inside the cavity.
