Neubau201824 Aug 2017 13:01A new garage solution is being considered for a property where the driveway slopes down about 3 meters (10 feet) over a length of 12 meters (39 feet).
I have looked online. There are prefabricated garages that can withstand earth pressure.
So, in my opinion, one option could be to build two of these garages as a kind of basement/storage space underneath, with a large garage area above.
Is there a standard size of 7 x 7 meters (23 x 23 feet) external dimension? Delivery in the 824 area...
Of course, earthworks and a foundation are needed. But what I am mainly interested in right now is: Are there such prefabricated garages available? What do they cost, including a pitched roof on top – just to get an idea of the product effort involved?
Electrical installation should be included. Access and building permit/planning permission are not an issue.
A garage that is already 3 m (10 feet) below street level is also planned to have a basement beneath it (again with garages; as a double garage with two single garages underneath)?
Precast garages can also be assembled on site from elements; those that need to fit on a truck in one piece are usually split into two parts for dimensions of about 7 x 7 m (23 x 23 feet), although an open middle section is possible.
Pitched roofs will need to be added on site during construction.
Assuming you have disabled your ad blocker, you may see relevant advertisements alongside your post based on your search term.
Neubau201824 Aug 2017 14:4511ant – please read again, this is not stated like that in the description of the location.
Thanks for the suggestion of specialist companies, I wouldn’t have thought of that at all
Where are the useful contributions according to my question?
Neubau2018 schrieb:
11ant – please read again, this is not stated like that in the site description. What exactly is not stated? It says:
Neubau2018 schrieb:
the driveway of about 12 m (39 feet) slopes down approximately 3 m (10 feet) So, at the end of the 12 m (39 feet) long driveway, the garage is 3 m (10 feet) lower than the start of the driveway;
Neubau2018 schrieb:
to build two such garages basically as basement/storage underneath, two single prefabricated garages are planned underneath the main garage.
Neubau2018 schrieb:
above it a large-span garage. Are there standard sizes of 7 x 7 m (23 x 23 feet) external dimensions? Regarding the main garage (which sits on top of the two single prefabricated garages), I understand the term “standard size” as an indication that this should also be a prefabricated garage.
So, all together: a 7 x 7 m (23 x 23 feet) garage at the end of a sloping driveway, 3 m (10 feet) below street level, with a basement consisting of two garages, for example each 3.5 x 7 m (11.5 x 23 feet), all as prefabricated garages.
Which part do you think should have been understood differently, and how?
(a picture is worth a thousand words)
Neubau201824 Aug 2017 16:03The sloping driveway is intended to be used to provide ground-level access to a large garage, with two single garages below taking advantage of the slope to serve as storage rooms instead of a basement. Clear now?
