ᐅ Single-Family Home – Is Poroton the Right Choice?
Created on: 2 Aug 2016 10:35
robi782
robi782
2 Aug 2016 10:35
So, we are facing a decision between two building contracts. We will receive the final offers with all changes in the coming days.
Building contract #1 uses 17.5cm (7 inches) Poroton T18 blocks, while building contract #2 uses 24cm (9.5 inches) Poroton T18 blocks. External thermal insulation composite system (ETICS) is specified as 20cm (8 inches) for both. Now I’m wondering if 17.5cm (7 inches) could present any disadvantages for us, and if so, which ones? Based on gut feeling and the included services, we actually prefer building contract #1.
Thank you very much in advance for your help.
toxicmolotof
2 Aug 2016 14:02
Why use Poroton in the first place and then apply ETICS on top?
You might as well use solid sand-lime bricks and get proper sound insulation. The external thermal insulation composite system (ETICS) should take care of the thermal insulation anyway.
Sometimes I just don’t get it, but then again, I’m not an architect.
robi782
2 Aug 2016 14:06
ETICS because both builders offered it together with the T18, and the T18 alone does not provide any thermal insulation! But thanks for your post.
toxicmolotof
2 Aug 2016 14:16
I have nothing against external thermal insulation composite systems (ETICS / cavity wall insulation)... but then why on earth use Poroton?
What are the advantages of this brick?
By the way, I consider it simply wrong that it does not provide any thermal insulation.
robi782
2 Aug 2016 14:33
@toxicmolotow
link removed; Construction expert, you should take a closer look at the T18 before making such comments...
And once again, the builder only offers Poroton or Ytong like most do today. Therefore, as I did not mention in my question, sand-lime brick is not under consideration.
toxicmolotof
2 Aug 2016 18:20
@robi782
What exactly do you want from me? Are you selling the bricks? Or do you just not want to answer my follow-up questions?
Like most people nowadays? Interesting, can I get proof of that? Especially in combination with external thermal insulation composite systems (ETICS).
You will have fun attaching cabinets and shelves to the walls with both types of bricks. Plus, there’s chasing involved.
Any more questions?
